993 Forum 1995-1998
Clutch and Flywheel Labor Costs
Old 04-26-2011, 11:23 AM
Oz-ATL
Oz-ATL's Avatar
Default Clutch and Flywheel Labor Costs
The dealer wants $2200 plus anything extra they have to do while replacing my clutch/flywheel setup. This obviously seems about $600 high to me.
What's a decent price for a shop to swap out a clutch/flywheel set with Rear Main Seal?
Old 04-26-2011, 11:43 AM
matt777
matt777's Avatar
IIRC labor is typically around 10 hours if they only drop the transaxle. It definitely should not be more than that. Does the $2200 include the clutch and related parts?
Old 04-26-2011, 01:20 PM
goofballdeluxe
goofballdeluxe's Avatar
If they drop the engine, I'd say you should be able to find an indy wrench to do the work in 10-15 hours at $100/hr. That's not including the parts, just labor.
Old 04-26-2011, 01:54 PM
Makmov
Makmov's Avatar
book time is 12.1
Old 04-26-2011, 02:59 PM
EckFe1
EckFe1's Avatar
I paid Euros 700.- and supplied the LWF Supercup RS clutch kit. It included the crank seal too. Motor stayed in.
Ed
Old 04-26-2011, 03:40 PM
tjangi
tjangi's Avatar
it varies between 9-13 hours. Avg mechanic cost about USD 80-90/hr... so about USD 1,200 max in NJ
Old 04-26-2011, 03:50 PM
Oz-ATL
Oz-ATL's Avatar
$1200-1500 is what I was expecting. Even at the dealer $125hr ($1515), I need to figure out where the other $700 is coming from since they know I'll be supplying the parts.
There is a little bit more labor to disconnect SC and IC parts but that can't take more than an hour.
Old 04-26-2011, 04:29 PM
goofballdeluxe
The $700 is the dealer mark-up. That's why no one takes their 993 to the dealer; they don't know these cars as well, and they over-charge.
Old 04-26-2011, 05:38 PM
jainbaby
jainbaby's Avatar
Just had it done in NJ 3 weeks ago and they did new front bonnet shocks (pain in the...)
Total labor was $1115.
I had new clutch and LWF installed.
Old 04-26-2011, 06:58 PM
95 C4 993
95 C4 993's Avatar
I spent $3398.60--new clutch, oil, LWF and labor. Engine removed. This was 2/12/04--7 years ago and 38,859 on the clock.
$1870.00 Clutch/Flywheel
$28.99 for rear seal
$99.99 for 10 quarts of oil (I just had my oil changed 800 miles prior--used same filters)
$1099.46 labor
$107.79--Idle speed adjustment
$192.36 tax
I had my front seal replaced at the time---total job $447.58
Rotars turned--front and rear --$215.58
Total that shop trip: $4152.91 and I got a car that stalls every now and then!!
Old 04-26-2011, 07:09 PM
FisterD
FisterD's Avatar
LWF kit-$1795 (everything needed incl. RMS)
Labor-$760
Old 04-26-2011, 07:12 PM
RDS928S
RDS928S's Avatar
Who did the work in NJ?
Rich
Old 04-27-2011, 11:45 AM
Oz-ATL
Oz-ATL's Avatar
I asked the dealer about the quote and they said it was a 16 hour job instead of 12. Seems like a hell of a lot of padding to me. wow. Indy here I come. Now to figure out which one here in Atlanta......
Suggestions?
Old 04-27-2011, 12:06 PM
Makmov
Makmov's Avatar
Usually when the have some rediculous labor they are saying in the nicest possible way, they don't want to work on your car.
Old 04-27-2011, 08:43 PM
black ice
black ice's Avatar
I have no idea how anyone is able to get all that lined up for reassembly without dropping the engine too...
Quick Reply: Clutch and Flywheel Labor Costs
