Sports Seats?
Sports Seats?
I have sports seats and the drivers side is a 'little' more worn then the passenger side. The wear is in the usual spot where the belt comes over the shoulder part of the seat, as well as a little on the lumber on the left side.
So here is the question. Can I swap the entire seat back with the passenger one? I know I can remove the leather cover, but thinking this maybe easier. Do I need to remove the hard shell back as well (was thinking of getting them painted anyway) to do this?
I know the bottoms are not exchangeable, since they have the power controls, but the tops look the same.
Yes, its possible and I have done it, but you do have to take the seat apart quite a bit, including taking the back off the sport seats. I did exactly the same thing, I would rotate the left to right to even out the bolster wear.
I sold the sport seats quite a while ago so I do not remember the exact procedure, but I just took it apart and figured it out...I seem to remember its not that hard. Take a peek, it you get scared, take it to a good seat shop and they can do it.
Cheers,
Mike
Cheers,
Mike
Go to a good leather/interior repair shop and have them fix the wear marks on the bolsters. Not expensive and works great.
Here is my drivers side bolster. This was fixed in a matter of 40 minutes.
Before.....
After.....
I also had this done on my previous 964 and 3 years later it still looked great! The wear became consistant with how the rest of the seat had aged and looked great!
Derek
Before.....
After.....
Derek
