Voltmeter 12 V LCD gauge
The ashtray solution shown above with the matching display color looks nice.
I‘m using a bluetooth voltmeter installed on the battery. It‘s invisible, has graphs like voltage over time etc on the app and can be checked from outside the car too.
Premium Sponsor
Its called the "Battery Tracker", and made by Antigravity Batteries. Installation takes about a minute and is as simple as loosening your battery clamp bolt, and sliding in the Battery Trackers terminals behind the loosened bolt and tightening. No need to discounnect the battery or do anything more than loosen and tighten the bolt on the clamps. Then put the app on your phone and then it will give you real-time voltage and a history of voltage up to 30 days. It can also send you warning in your notifications on your phone.
You can see it here> https://antigravitybatteries.com/pro...ker-lead-acid/
Video below.....
And why does the silly App need a "location" for improved accuracy for it to work? BS like that pi$$es me off. Taking a voltage reading has nothing to do with where I am on planet earth. LOL
