993 Forum 1995-1998
Fister golden rod is worth it's weight in gold.
Old 04-01-2011, 12:17 AM
nile13
nile13's Avatar
Oh, I'm enjoying it every day - this is a daily driver cab. Oh, and it's snowing today in Boston.
Old 04-01-2011, 01:05 AM
Paul K
Paul K's Avatar
+993. Great, easy upgrade. Just make sure you replace the plastic cups on each end while you're in there.
Old 04-01-2011, 01:33 AM
nile13
nile13's Avatar
Part numbers for the cups please?
Old 04-01-2011, 02:18 AM
Cincy_Ron
Cincy_Ron's Avatar
Sweet, glad to see so many like this mod. I got the golden rod and short shift kit in the mail a couple of weeks ago. Need to carve out some time to do the install in the next couple of days.
Paul, I'd like some more info on the cups you recommend replacing also.
Old 04-01-2011, 09:28 AM
Paul K
Paul K's Avatar
I don't have the cup part # handy, but there's one on each end, and they're usually shot. It's a 928 part number. There was a thread about this recently...
Old 04-01-2011, 10:41 AM
targagr
targagr's Avatar
I already have the RS SSK...will i see an even better improvement(sharp) if i add the Golden rod to that?
Old 04-01-2011, 11:53 AM
NickyP
NickyP's Avatar
Originally Posted by sdcabrio
I've been thinking about this mod. Did you (can you)? add a short shift kit as well?
Hey Brian-
Let's get together and go for a drive. You can drive my car; I have all Darin's popular upgrades- SSK, golden rod and Stage III's. Pure goodness...
Old 04-01-2011, 12:11 PM
nile13
nile13's Avatar
No problem, Paul, we'll find it.
Suggestion to Darin and Mark: guys, you might want to supply the plastic cups as an option with Golden Rod for extra charge. Would make it easier as a package. For when I'm ready in a month or so
Old 04-01-2011, 12:14 PM
FisterD
FisterD's Avatar
If you install the FDM SSK, you do not have to worry about the plastic cups. We eliminate this weak link by using stainless rod ends. This ensures a nice tight trouble/failure free front linkage.
Old 04-01-2011, 12:17 PM
MarkD
MarkD's Avatar
Ron, you don;t need the cups with our SSK. We eliminate the ball/cup joint to improve shift feel and eliminate the possbility of being stranded due to a failed cup.
yes, there is a floppy rubber joint in the shift rod that we replace with a u-joint, ala Porsche RS shift rod.
The 993 is the first 911 to have this dampening in the shift rod.
Old 04-01-2011, 12:26 PM
FisterD
FisterD's Avatar
By the way, I would love to take all of the credit for the SSK/Golden Rod but it is an FDM venture (Fister-DiPietro Motorsports) and was designed and built by me AND MarkD
Old 04-01-2011, 02:56 PM
sdcabrio
sdcabrio's Avatar
Originally Posted by NickyP
Hey Brian-
Nick,
I'd be down for that. All I have is the stage IIIs, but you can hear them a little better in a cab. We should head over to Adam's on going engine re-building party. You can never have enough beer drinking supervisors on a project like that.
Old 04-02-2011, 02:55 AM
nile13
nile13's Avatar
Darin, do you happen to know if plastic cups needed with your rod and Weltmeister's short shifter?
Old 04-02-2011, 03:35 AM
FisterD
FisterD's Avatar
There are no plastic cups associated with the Golden Rod. The cups are used on the stock front linkage. I don't think the Westmeister kit uses them.
Old 04-02-2011, 09:16 AM
firesm
firesm's Avatar
Here's a picture I posted on my thread about my FDM SSK and Golden Rod installation. It shows the difference between the original rod and the Golden Rod - this should answer your question in less than a thousand words... how about one - yes!
Quick Reply: Fister golden rod is worth it's weight in gold.
