993 Forum 1995-1998
Too low?
Old 03-23-2011, 10:42 PM
Resident Sicko
Resident Sicko's Avatar
Default Too low?
What ride height is everyone running?
I measured from ground to underside of fender lip and rocker to ensure a slight "rake" prior to corner balance. Front still looks too low for the rear.
Thoughts?
Old 03-23-2011, 10:50 PM
jscott82
jscott82's Avatar
I would agree, looks like too much rake to my eye..... I would use RS spec as a base line and go higher or lower from there... RS spec is 124mm front 107mm rear.
The other thing, don’t use the body to measure ride height, it can be off considerably... Use the factory frame locations (I’m sure someone can dig up picture/diagram if you don’t have them).
Old 03-23-2011, 10:55 PM
Resident Sicko
Ahh yes, I remember reading about that while trolling prior to becoming a member. Thank you for the reminder.
Old 03-23-2011, 11:02 PM
jscott82
jscott82's Avatar
BTW... Love the car... only thing better than a 993 c2 is a c2s.
Charlotte, SC = Fort Mill???
Old 03-23-2011, 11:56 PM
ironimages
ironimages's Avatar
Lower the back a tad..
Old 03-24-2011, 12:32 AM
user 70801213
user 70801213's Avatar
is that an R8 behind? "looks" good to me....
Old 03-24-2011, 12:36 AM
P-daddy
P-daddy's Avatar
In the third pic, the front does look too low compared to the front. Beautiful car Sicko!
Old 03-24-2011, 12:51 AM
shadow993
shadow993's Avatar
Check your glasses...that is a giant Mazda badge.
I dig the 70's mustang rake.
Old 03-24-2011, 04:01 AM
Thatcher
Thatcher's Avatar
damn.. stunning. keep those FM5's.
Old 03-24-2011, 09:38 AM
Resident Sicko
Car is too loud to get it back on the ramps last night without waking the neighbors..but shoudl be sitting correct tonight.
May consider additng a 5mm spacer to each rear as well to match the front. On 18x8.5 and 18x11 each at +45, Kudos to Thatcher on offset info. Yes, front is perfect, but rear could come out to 40mm with the 11" rear.
Will post pics of the update.
Thank you all for the kind comments.
BTW: Mazda CX-7. Not my first choice, but we have Ford A plan and liked it better than the Edge....However after 3 years of ownership, I have to admit it is a very fun vehicle. Thrashy turbo 4 cyl around town, but scoots on the freeway and handles like a champ evcen with AWD off road capability as discovered while renting a tree house in the Blue Ridge Mountains.
Next best thing to an Audi AllRoad.
Old 03-24-2011, 10:03 AM
Bill Verburg
Bill Verburg's Avatar
Are you sure that the front is 8.5ET45?
Old 03-24-2011, 11:24 AM
ABCar
ABCar's Avatar
Here is something from my files that was posted on RL previously
USA Standard: Front 174mm, Rear 157mm
USA Sport: Front 174mm, Rear 157mm
ROW Standard: Front 154mm, Rear 147mm
ROW Sport: Front 144mm, Rear 127mm
Carrera S/4S: Same as Sport for USA / ROW as appropriate
Carrera RS: Front 124mm, Rear 107mm
(Measurements are plus/minus 10mm)
These ride heights are relative to Porsche specified suspension reference points, which are illustrated below. Although we often speak in terms of fender heights out of convenience (typically measured from the ground, through the center of the wheel, to the fender), the most accurate measurements will be based on the reference points. That being said, most 993s using ROW Standard or Sport settings have fender heights of about 25¼” to about 25¾”. As a rule of thumb, the front fender height should be about ¼” HIGHER than the rear fender height to achieve the desired 1 degree downslope (yes, that sentence is correct. ).
My settings are about 25" front and 24 3/8 rear (fender).
Love the look of your car and the Fikse wheels are just the best.
Old 03-24-2011, 11:41 AM
TMc993
TMc993's Avatar
The key is to get the ride heights relative to the suspension points (See above) correct. Once that is correct, the fender height and rake on the car should be correct.
Old 03-24-2011, 11:48 AM
Bill Verburg
w/ RS wheel carriers and solid rear side mounts you can go lower than the RS min spec
Old 03-24-2011, 12:12 PM
gaby1088
gaby1088's Avatar
thats not too low, your not too low until its uncomfortable to drive! It looks PERFECT the way you have it! You guys are making me catch the Mod Bug!
my DD
Quick Reply: Too low?
