Went for an early Connecticut drive this morning when it was a bit chilly outside - about 30. Both my son and I noticed that there was a cool breeze/draft coming from behind the inside door handles. Is this common?
There is a tsb for this but it didn't do my car much good. A very inelegant but effective solution is to stuff half a shop towel in each side around the rod
Yeah, its hard to stop that little draft that hits you on the side of the leg. The TSB calls for a piece of felt around the pull rod for the door latch...does not work. I have not tried the rag trick...maybe next time the doors are apart! :-)
no door disassembly needed.
Just take a scott shop towel...tear it in half.
Pull the inner handle like you're opening the door, and stuff the rag in that hole around the rod. (wow, that um, didn't sound as sexual in my head)
