Cab Top Finally Manual
Since I was a spectator, I will add my 2 cents worth. Bill had Mike disconnect the power to the motors while the top was up. This will keep it from cycling, and when you are ready to reconnect, just put the top up and the motor is in the right position when the power is re-connected.
This may be a given to you cab guys, but it seemed to be a small detail to a coupe guy.![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Coupes Rule![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
Emerald
Coupes Rule
Emerald
Emerald
Coupes Rule
Emerald
Yes, this will keep the cab top "transmissions" aligned with the top so that if you need to reconnect it you don't have to realign the assembly.
They are located behind the rear seats - right?
I don't think you are in any danger at all. As a matter of fact when we did mine I only unplugged one of the rear motors. When I went to press the switch to unlock the motors on the windshield frame we heard the transmission motor engage. No problem I just locked down the top and unplugged the remaining motor. So basically put the top all the way in the closed position and unplug the rear motors. Remember there are 2 plugs back there, one for each motor. And yes they are located behind the rear seats
Mike
Mike
And while you’re at it, with your micro fibre towel whisk off the dust from the rear window and as you fold the top down place the micro fibre towel over the plastic as a liner. Stops the dust and plastic chafing against the hood fabric.
I have had all of my problems with the top latch motors. I have broken two sets to the point where I can not spin the worm drive to get an undamaged section to work with--I am referring to the fix were you split the case and turn the worm drive 90 degrees. I am in maunal mode but for different reason than stated. FVD has some rebuilts available with what they call stronger parts but I just dont know what to do. I am spinning a screwdriver to latch it now. If I do get replacements I do like the idea of using the top button just to latch the top but not lift the top but I have never expereiced any problems of that nature.
Mike
Mike
