Wet foot wells in 993 Targa
I'm buying a 993 Targa that the has been stored outside under a cover, all the foot wells are wet but not sitting in water, none of the rest of the interior carpet was wet above the floor line i.e behind rear seats, front of front footwells, below doors which is where I would look, after checking the drainage holes if it had a standard sunroof. I will dry the car out when I get it and hope its not a permanent problem but......... being a newbie to 993 Targa's where are the drainage holes and places to check with a targa roof.
If it's been sitting with wet carpets, it may have a mildew/mold issue. To me, this is a horrible smell that would require replacing carpets and foam. Check it out carefully before you buy.
Check out the tsb's and articles on my site www.pcarworkshop.com for Targa info to look for leaks, etc.
The front drains actually drain into the door seals, run inside the seal and then drain out the bottom...front foot wells sounds more like a front windshield leak. These cars often corrode at the bottom corners of the windshield, starting from behind the rubber seal. Was that checked?
I would pull the mats, then the foam at the bottom of the mats. That is glued down in spots so be careful, use a sharp knife to cut the carpet from the foam. Put a heater inside the car, open the roof a bit, and run it for a few days.
I had some major water issues (all solved now), and never had mildew or smells, I think both the foam and carpet is treated well.
Water is hard to track, so it might take some time. Are you sure the floor behind the seats is not wet? That is often a gathering point for the moisture from leaks.
Cheers,
Mike
Cheers,
Mike
Thanks Guys, I will check everything suggested, there wasnt a musty smell or any sign of mould. Its in the front and back footwells
Regarding front windscreen it has the usual rust in the bottom corner, where would it leak in around there.
Cheers,
Mike
