993 Forum 1995-1998
Ventilation Fan Running All The Time...
Old 02-24-2011, 02:26 PM
vincer77
vincer77's Avatar
Default Ventilation Fan Running All The Time...
Last couple of times I've driven my '97 Cab, I hear what sounds like the ventilation fan running at low speed. The controls are off. According to Streater the off switch is only a low setting (2V). Wonder why I never noticed this before.
Is this what happens in your car?
Old 02-24-2011, 02:50 PM
ble2011
ble2011's Avatar
Check the DIY section under "How to remove whirring sound from 993 dash".
Old 02-24-2011, 05:00 PM
2Many Cars
2Many Cars's Avatar
I've never noticed on my car but I know some manufacturers do that so there is always some air moving through the HVAC system. I believe the theory is to avoid potential mold growth from any moisture from accumulating in infrequently used systems.
Old 02-24-2011, 05:05 PM
ToreB
ToreB's Avatar
The fans should shut completely off when the fan control **** is at minimum setting. I am therefore pretty sure you hear the CCU fan. It stays on for some time after ignition off and can make a whirring noise and it can be a bit irritating. Easy to change though.
www.ccu.tore.bergvill.com
Cheers,
Tore
Old 02-24-2011, 06:33 PM
vincer77
vincer77's Avatar
The sound I hear is when they ignition is on - not off.
Quick Reply: Ventilation Fan Running All The Time...
