993 Forum 1995-1998
993 C2S Refurbish Journal
Old Jul 6, 2011 | 12:34 PM
  #61
Chuck W.'s Avatar
Chuck W.
Originally Posted by Resident Sicko
installed Hella de Micro.
How hard was it to install the Hella de Micro lights into the unit. Any cutting or was it a plug and play?
I found this link with four different Hella de Micro models. Which one did you use? TIA
http://4wheelonline.com/Hella_Micro_...s_Lights.28275
Old Jul 6, 2011 | 02:28 PM
  #62
Resident Sicko's Avatar
Resident Sicko
Hi Chuck,
I bought the standard DE units off Amazon since most of the extras were not going to be needed. (brackets, switch, wiring, etc.) Then upgraded the bulbs to a true white (PIAA)
There was a fair amount of cutting, molesting, slicing and glue...but did it all with a Dremel and regular attachments. (All in all took about 2 hours after ducts were painted)
Used this link as guidance:
http://www.pcarworkshop.com/index.ph...lla_Fog_Lights
Old Jul 6, 2011 | 03:45 PM
  #63
Chuck W.'s Avatar
Chuck W.
Many thanks!
Old Jul 7, 2011 | 10:25 AM
  #64
Resident Sicko
New goodies arrived. Got some work to do!
Old Jul 7, 2011 | 01:45 PM
  #65
axl911's Avatar
axl911
Those + pin your tie rods and they'll transform the car!!
Old Jul 7, 2011 | 02:26 PM
  #66
Resident Sicko
New information to me....researching now.
Help me understand the reason behind the Tie Rod Pin mod as I fail to have found anything that explans it better than this:
https://rennlist.com/forums/993-foru...hapter-ii.html
Is this modification to eliminate any "slop" in the steering wheel? If so, why would there be so much slop in the first place? (looking at cross/section shown on thread) If setting a bolt in the tie rod ends is needed, would an allignment also be in order to "true" up each side?
Old Jul 7, 2011 | 03:35 PM
  #67
axl911's Avatar
axl911
[QUOTE=Is this modification to eliminate any "slop" in the steering wheel? If so, why would there be so much slop in the first place? (looking at cross/section shown on thread) If setting a bolt in the tie rod ends is needed, would an allignment also be in order to "true" up each side?[/QUOTE]
Unless there is a problem with your steering rack, yes it takes out slop. Best way to describe it was that the steering feel (when car is moving) is tighter, more feel, more responsive. You move the steering wheel 1mm, the car immediate moves 1mm.
I didn't have to do any trueing up when I pinned the tie rods. When you do the bushings, mark all the bolt locations/settings.
Old Jul 9, 2011 | 03:35 PM
  #68
Resident Sicko
Thanks for the tip! Will perform the steering roll pin mod while I am at it! Can't wait!
Old Jul 17, 2011 | 09:40 PM
  #69
Resident Sicko
Old:
New:
Old Jul 18, 2011 | 11:24 AM
  #70
H.H.Chinn's Avatar
H.H.Chinn
^^ Did you polish these or did you have them done?^^
Old Jul 22, 2011 | 09:53 AM
  #71
993polartip's Avatar
993polartip
great work!! i love all your tweaks and am now inspired to keep my car clean!
thank you for sharing
Old Jul 22, 2011 | 10:22 AM
  #72
CalvinC4S's Avatar
CalvinC4S
Nice work! whos exhaust mod was that and any before/after opinions with your mod?
More bark, i'll bet.
Old Jul 22, 2011 | 02:23 PM
  #73
Resident Sicko
More on exhaust work here:
https://rennlist.com/forums/993-foru...-overhaul.html
Old Jul 25, 2011 | 09:14 AM
  #74
Resident Sicko
New control arms cleaned up and clear coated. Walrod bushings installed. All going in this week with new beefy front sway bar, tie rod roll pins and stiffer motor mounts. Woo Hoo!
Old Jul 25, 2011 | 11:59 AM
  #75
95_993's Avatar
95_993
Wow....you've been busy! Looks great.
