993 Forum 1995-1998
Considering 348/360 vs 993...experiences?
Old 02-26-2011 | 11:22 PM
  #136
993Brendan's Avatar
993Brendan
Great thread- a good read for someone like me that has always loved Ferraris, but is too scared to own one due to the running costs. I have my sights set on an orange 997 GT3RS.1 in a few years that will hopefully satisfy my urge for something a little quicker (I'd keep the 993, of course...can never let that go!).
TCS- welcome to the 993 board. I'm a lurker on the 997 GT3 board and am a big fan of your GT3RS (both of them).
Old 03-02-2011 | 02:23 AM
  #137
eloyex's Avatar
eloyex
Originally Posted by chris walrod
With each model, the Ferrari gets less maintenance intensive. If you must buy an F-car, buy the newest model you can afford. Sometimes its not so much the labor (DIY), its the parts pricing structure thats insane. Make's Porsche a complete bargain to rebuild!!
150% true ...
i have studied the point many times,as i like ferraris a lot ...
348 has many many minor issues.
is not a bad car, but requires a lot of tricky maintenance all of the time.
it has a nice frame , as most of the ferraris .. !! parts are stratospherically expensive !!!!!!!
360 is much better option and you can get a decent one, for less than 100K.
probably lot less than that if you seek well ...
a 430 is even better, more civilized , more reliable, and real nice car.
maintenance as expected is expensive . You can get a nice one in the vecinities of 110K. It would be my choice.
excuse my poor english !!!!!!!!
Old 03-02-2011 | 02:54 AM
  #138
FlatSix911's Avatar
FlatSix911
Originally Posted by Robin 993DX
Well...
Here is the answer. You have to remove both rear wheel well liners, but before you can do that you have to remove the engine bay panels, as there are two bolts that's mounted from the inside of the engine bay that holds the liners in. (idiots!) Also you will have to remove the emission canister along with the O2 sensor connectors first, as they are mounted on top of the liner.
Then you have to remove the engine bay access panel from the inside of the car, before you can do that you will have to remove all the interior panels, and then about 50 bolts to remove the cover. On the spider it is even more difficult, you will have to remove the storage bin which requires 1 torx bit and a 10mm wrench.
After you replaced the spark plugs you will need to find a shop or the dealer with a SD2 to reset the computer to detect new spark plugs. Make no sense, but this is what the SM requires.
To bleed the clutch slave it fairly easy, but wouldn't work with a pressure bleeder, so it is a two people job. Someone needs to push the pedal while you bleed. With the F1 forget it you will need a SD2 system. But bleeding the system will most likely crack the bleeder union, which will require a replacement unit as the stock unit is very prong to cracking, so upgrading to a Hill Engineering unit is a must. While you bleed the clutch slave (thrust bearing) is part of the system (no clutch slave cylinder like the ones on the Porsche's), you will most likely find out that your thrust bearing seals are leaking, which will require a complete transmission removal. Once you have remove the transmission you find the thrust bearing is making noise, then it would probably be wise to upgrade to another Hills Engineering thrust bearing as the factory unit is crap.
While you are at it, you should remove the clutch and flywheel replace the RMS, since the factory one are also prong to leaking. While you are at it, the pilot bearing too....
The list goes on and on, never ends.
Oh yeah while you are at it, replace the engine oil temp sensor as the factory unit is made by Fiat and are prong to break and give false temp reading.
Robin, I lust for the Ferrari feel, but I would rather have cross threaded nuts before enduring this ...
Old 04-20-2011 | 12:02 PM
  #139
Falcondrivr's Avatar
Falcondrivr
Originally Posted by cavlino
Here are a few pictures.
But what about the John Deere on the lift? Reliable? Running cost? How does it track?
Old 04-22-2011 | 12:46 AM
  #140
cavlino's Avatar
cavlino
That's my Wife's, she tells me nothing about all those things, she really likes it though and the lawn is cut in minutes. I guess that means it tracks very fast!
Old 04-25-2011 | 08:17 PM
  #141
Toycar 1's Avatar
Toycar 1
The traction is awesome, it runs circles around the 993 and the Ferrari. Could use some more top speed though, can't decide if I should add a supercharger or if I should turbo it...
"The wife"
Old 04-25-2011 | 08:31 PM
  #142
Spidey 993
Guest
Posts: n/a
You gotta consider resale value...
"The wife"
Old 04-25-2011 | 09:13 PM
  #143
bb993tt's Avatar
bb993tt
Originally Posted by niche
I love reading your posts on the Ferrari... I could barely deal with the Ruf's exhaust leak, much less all the stuff you've gone through.
J, I assume you're talking about the one-off RUF-built center exhaust on your turboR? When I had my car converted in DE I enquired about having this done as well. They refused to do it. Claimed they'd had too many problems with the one they'd done previously. So I had to stick with the tried and true dual exhaust. Didn't look as cool but I had zero exhaust problems going forward.
