Carnewal 100/200 Cell Cat Conversions
Seared
This has been done before in the UK. Mark Budgen who had a supercharged 993 had had it done to his cat. Whilst it free up the cat it'll still weigh a ton!
Cheers,
David
Cheers,
David
Hi
I bought the 100 cell inserts from Gert and had them fitted to my standard enclosure by a very good welder I know. He said it was a pig of a job. I have got pictures somewhere. Looking at the old ones I would guess that the 100 cell ones would give a performance boost. They certainly sound better. The old cat was still passing the UK MOT at 185k miles.
Berni
Berni
Hi Mark,
Long time, no talk! Hope you are well. One day I may try your route though with two children that's probably not going to happen for a while!
Cheers,
David
Cheers,
David
Hi
Berni
Berni
Why are the OEM cats so much heavier? Is it the casing or the higher density cell material inside?
Anyone know what weight saving is gained by replacing the innards with 100 or 200 cell guts?
Is that a job most muffler shops could do, or is it more specialized than that?
I would assume it is the heavy exterior that has most of the weight. When I swapped to my 100 cell cats I saved 15 to 20lbs. The original cat is soooo heavy!
I've got the FD 200 Cell SC's and they weigh a good 20lbs less than the OEM, MUCH less heat back there vs OEM as well. The 200s moved the torque higher in the rev band, I imagine the 100s would move it higher?
