checking oil...
checking oil...
At the risk of sounding really, really inept..
When I check the oil, the owner's manual says the oil fill cap should be removed. Am I missing something? It doesn't seem to make a difference on the reading whether or not the cap is in place. The oil level guage reads really low, but the dipstick says it's full. Pressure always more than 3.5 bars.
What's up?
What's up?
As others will chime in, the gauge may be a good rough indicator once you know how yours is calibrated.
But to check oil level accurately, you need.
1. HOT oil
2. Level ground
3. A minute of idling, and;
4. Check your dipstick - by definition, your cap will be off!
Good luck!
M
1. HOT oil
2. Level ground
Good luck!
M
1. HOT oil
2. Level ground
Good luck!
M
1. HOT oil
2. Level ground
Good luck!
M
Leave the filler cap on (as has been said before).
As for the bars....no, at least 3.5 while driving.
Thanks for the responses.
i had the same issue yesterday, the oil gauge was right on the cusp of being in red (even the the dipstick was a little more than half). I bought a few quarts of oil and i couldnt get in half a quart before the oil filler overflowed. Now the gauge reads a little more than before but less than half, but if i try filling the car with oil then it overflows! i didnt want to make a thread because there has been so many but i cant find my issue among those reads
There definitely are variations between the accuracy of the gauge between cars.
Cheers,
Mike
Plus keep in mind that oil level indication for the gauge will show a noticeable increase with spirited driving because with heat there is an expansion and tiny air bubbles mixed into the oil because of the churning-action inside the engine.
Good advice by all so far.
Note the the oil filler tube has a filter screen down inside. If you add oil too fast, you might exceed the flow that the screen can handle and the oil you are adding may backup and overflow as if you had overfilled. Coming from an SC, this screen is new to me and I make a mess nearly every time I add oil.
Glad to hear someone else has oil overflowing issues. After I bought mine, I had oil overflowing almost every time. I found out, you need to add it real slow.
I've had all these 'new to Porsche' oil issues as well!
But, now how do you actually see the oil level on the dipstick? Isn't it next to impossible? Gold oil, against gold metal: what were they thinking?
Or, am I either just plain stupid, or blind? Or both?
Is there a 'technique' I need to know?!
Thanks!
Thanks!
Thanks!
Thanks!
(Oh, boy, I just re-read that... Seriously, I'm talking about reading the oil level in the car here...)
