Where to buy a single Bilstein PSS10 drop link?
Assuming no further issues, I plan to get the car out a bit more than last season!
I usually run with Track Daze but I may have to venture out of my comfort zone and try a few other groups.
I'm assuming you get out to Summit and NJMP quite a bit, right?
Believe it or not, I've never made it all the way down to VIR. I've been meaning to for years but just haven't been able to schedule the 4 days I'd basically need to make it there and back.
just like their products. They make lots of good stuff for the 993 suspension, similar products to what Cary Eisenlohr makes at ERP. ERP is NOT elephant racing...ERP makes really trick suspension pieces. I have their toe links.
No affiliation to Tarrett or ERP
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
I have ERP toe links as well.
unfortunately you need to remove the coilover from the car, remove the springs and DL mount, then install the locking collar and add all the bits you just removed.
please consider having another shop do the work if you do not DIY. The original shop was not your friend.
This photo shows P10's with Euro Turbo ARB and RS+10mm ride height.
any lower and you would probably need to route the ARB under the toe link.
good luck.
Craig
FWIW the additional locking collar is not required if the perch is oriented correctly.
However, there is nothing wrong with adding it... except the work and $ involved in another rear alignment
The shop fixed the drop link and reimbursed me for my additional cost. I let them know about tightening it down under load and so far after about 50 miles both drop links are holding firm. The first one barely lasted 10 miles...
Thanks everyone for your help. If I manage to break another one, I have a pair of additional collars for underneath the shock mount.
