Group Buy RS Motor Mounts from Sunset
The C2 and C4 mounts are interchangable on fit but I believe the C4 mounts are slightly tighter...not liike the RS or Wevos. Wevos are tighter and supposedly give a bit more noise and vibe than the RS.
Retail price on these are between 375 and 400.
Most of my knowledge is here-say...if someone needs to correct me, I yeild to the better informed...
The C4 mounts are stiffer than C2 but not as solid as RS. The Wevo is stiffer yet.
I debated between the Wevos and RS mounts. What I have been able to glean from these threads is it appears that there are more complaints from guys that have installed Wevos than with guys installing RS mounts. Also, I am a bit more comfortable running Porsche parts for authenticity reasons. If I had a car I ran at the track, I would consider Wevos, or if really serious, solid mounts.
If you have a C4, the C4 mounts are a less expensive option = less than $100 per mount if I remember correctly.
Again, there are more informed people here, but as I understand it, the RS mount fits C2 w/o problem. The RS is slightly different in height than the C4 so a spacer may have to be made. Others have said you do not need to. There is a thread discussing this that was live not too long ago.
Just ordered 2 sets (via email - I called, but Bob is off until Monday - I already have an account with them) - one for me and one for OFD. That should put us over the 10 required for the group buy.
Tks to Vince for setting up this group buy . Also tks to Steve for helping me get these to Canada.
I love this place, but my wallet always seems to be empty.
Cheers,
Geoff
Cheers,
Geoff
I will be reinforcing my carrier
they are $75 at rennline/pelican , just weld up onto your old unit.
http://www.rennline.com/Rennline-Eng...oductinfo/M04/
SC
SC
How many in the GB are going to reinforce their carriers?
My engine will be out for clucth and flywheel (LWF ) so "while I am in there" (I need to get used to typing that little phrase for sure!) I will be reinforcing my engine carrier. I broke one on my SC years ago and don't want lightning to strike twice.
