Mable Gray interior
Mable Gray interior
I sent Joanne the interior picture of my 993 which I believe it is the Marble Gray interior.
After spoke with Joanne, she doesnt think this is Marble gray and it might due to the picture effect from the computer. I am attaching the picture for the interior of my car, which I need to confirm with you whether my interior is Mable Gray? Please advise so I can order the color to dye my seat =)
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Based on your 1 photo, the above interior does look darker than Marbe Gray. More photos in different lighting may clarify.
However, the best place to start is usually the options sticker that should be on your bonnet, or similar records that originally came with your 993.
(BTW, Marbe Gray with black deviating dash & door armrests is one of my favorite interior combinations - nice!)
YMMV -- this photo is from a post where Rdelvalle implies he has Marble Gray; looks at least as dark as yours in this photo:
Hi Curve:
Thanks a bunch for the advise and your attachment picture. ou are right with the lighting because at the different lighting, the interior color of my car does look your the picture you attached.
Just to be 100% sure, do you or anyone know what is the Color Option Code for the Marble gray? I dont have any original sticker or anything, but I did noticed that I have the sticker under the bonnet of my hood =)
Again, thank you
Again, thank you
There are other resources around for decoding the option #s, but according to 993faq.com:
Originally Posted by Jim Walz
WQ is Marble Grey
xcusemi - That is definitely Marble Gray. I had Marble Gray in my 993 but it wore pretty poorly over the years and I converted the interior to black. The photo is a little dark, but that is Marble Gray. The steering wheel looks a little off though... maybe it is the photo, maybe the wheel has gotten a darker "patina" from use over the years?
The photo Jager posted above is Classic Gray.
Mark-- Right; I bit off on the post's thread title, "Looking for a rootwood shifter, marble gray boot"
Further inspection reveals:________________________________________________________________________
From my experience, Marble Gray is considered more of a 'bone white' or 'linen' in appearance ... closer to the color of your Rennlist sticker
This is more representative of what, IMHO, Marble Gray looks like 'in real life' / normal, sunny lighting...
From the "Marble Grey Interior" thread:
This is marble gray, I'm 99.8% certain of that.
The reason the steering wheel looks off in color is because the marble cars came with non-grey steering wheels, generally speaking (black or blue, depending on color scheme). The wood-insert wheel in OPs pic is most likely a later replacement, possibly in Classic, Rubicon or Florentine gray.
OP, a model year of your car would be helpful as gray colors changed over the years somewhat.
Thanks again!
I do agree that Joanne is a great asset for our cmmunity. I had a long talk with her, not just about paint..but also other things. She is very nice and sweet. I order one pint of Marble Gray and personally believe it should easily cover the front 2 seats along with the rear 2 seats.
I will let you guy know if I have alot left over, which offcourse I can offer this to any rennlist free of charge except for the shipping =)
Good luck. I am interested to get your review after you get the project done. My drivers seat bolster is getting a bit worn and I may do the same thing. Let us know!
xscuemi, the spec sheet from Colorplus I sent you wan't the answer for her to mix up a batch?
or maybe Marble Grey is a stock color for them now? Gonna go check their web site
EDIT: Nope, not on their site as a stock color.
Hi MarkD:
Again, thank you for your spec sheet. The sheet you gave me is for Marble Gray, but Joanne advised me base on the picture of the interior shot that I sent her, she doesnt think my interior is Mable Gray.
This is the reason I want to confirm with the board and from a few post below me, I am convince that my interior is Marble Gray and called Joanne to place the order. I told her to mix the color base on the spec sheet you provided.
Again, thank you everyone
