Need wiring diagrams...
I was riddled by the socket picture you had so I had time over the weekend and took a picture of the socket I have, only to find it is the same.
Now I have to investigate the porsche cable with an ohmmeter just checking continuity between the reader side plug, and the OBD plug. I am practically sure it is what I wrote above, but there is a chance I have reversed the pin numbers. Will let you know. regards
:I thought the round 19 pin connector was found in the early 993s as well. I think the changeover to the OBD II connector was sometime during the '95 model year."
That's correct.
The OBDII pins on '96 993 and later;
4,5 - grounds
15 - 'L' line
7 - 'K' line (bi-directional)
16 - #30 (constant 12 volts)
1 - #15 (key 'on' 12 volts)
The 'K' & 'L' lines are used to access the DME, Air Bag, ABS, CCU, & Alarm unit.
You can always determine the pin orientation by finding pin 16 which is always
'hot' with the key 'off', i.e. the only 'hot'.
That's correct.
4,5 - grounds
15 - 'L' line
Here is a chart I put together based on the 1995/2 wiring diagram out of the Porsche Repair Manual...
Good work, this chart is handy.
Pin 7 is K line, this is the bidirectional serial port to the Motronic engine control unit.
Pin 3 is K' line, (K-"marked") this is the bidirectional serial port to the CCU, SRS, (airbag) ABS and Alarm control units.
Cheers,
Tore
Cheers,
Tore
I don't know, but I'm sure this information is somewhere here on Rennlist. I see in the 993 schematics that the TN line is coming from the Motronic engine control.
Cheers,
Tore
Cheers,
Tore
