993 Forum 1995-1998
Chassis frame damage near suspension mount
Old 01-06-2011 | 05:20 PM
peter_s430's Avatar
peter_s430
6th Gear
I Owner, Coupe,50000 Miles, lowered suspension, No Dealer Service histories except the first 3 years ,but serviced regularly by independent German car Mechanic
The seller claims no accidents and original Paint
I haven't really spent much money on PPI, Carfax etc; I wanted to make sure that Car will be drivable in the future
The car is appears to be in good condition for naked & inexperienced person
Best Regards
Peter
Old 01-06-2011 | 06:22 PM
RS man's Avatar
RS man
Forget about this one......
Old 01-06-2011 | 06:26 PM
CorrdoBrit's Avatar
CorrdoBrit
With any car like a 993 you're buying the PO as much as the car itself. This one says run all over it.....
Plenty more without chassis issues for this sort of money or not much more. In the long run you'll be happier by skipping this one.....
Old 01-06-2011 | 06:38 PM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by peter_s430
The seller claims no accidents.
Peter,
A 993 is a robust sports car, overbuilt in some ways.
There is no way in the history of the universe that this "original owner" is telling the truth. Impossible.
He is obviously looking for a sucker. I would advise you not to pursue this rolling question mark.
Andreas
Old 01-06-2011 | 07:05 PM
RS man's Avatar
RS man
This statement is very true. How did he manage to leave such issues unadressed? What about other problems he is not disclosing?
Old 01-06-2011 | 07:41 PM
TheOtherEric's Avatar
TheOtherEric
Originally Posted by AOW162435
...He is obviously looking for a sucker. I would advise you not to pursue this rolling question mark.
+10000. You can get a nice 75k mile car for $25k (I did, as did others here). He knows what happened, he just isn't telling. That's MAJOR damage.
i'm guessing $3k+ to fix it (best case), plus $2k for all new front suspension parts, which are undoubtedly bent up too from a hit like that. There's a reason he's selling it "as is" -- he got the $6k estimate from his body shop and so he's looking for a sucker who thinks it's not that bad.
I'd say the car is worth maybe $18k. Could be a good race car starting point.
Old 01-06-2011 | 07:49 PM
Makmov's Avatar
Makmov
25K too much for this car.
The whole story has not come out yet.
Is that other lower panel in the picture cracked or just split at the seam?
What does the other tower look like. Is it about to fail or not a sign of failing. That would be a clue.
What about any of the suspension pick up points, A-arms, other damage. Looks like it was dropped off a cliff.
I can promise you a proper repair on this is thousands of dollars.
Old 01-06-2011 | 07:54 PM
TheOtherEric
Oh an it probably goes without saying, but you should DEFINITELY NOT DRIVE THIS CAR in its current condition. If you value your life, that is. This owner is nuckin futs if he's driving it like that.
Old 01-06-2011 | 07:56 PM
Makmov's Avatar
Makmov
Best Regards
Peter
Anything is fixable. I know of an AC Cobra that when off the road and down a mountian side and burned to nothing left but the frame and was restored.
Just guessing looking at that there is at least 5k, probably closer to 10k damage to fix it proper.
Strip in all down in the front. It will have to go on a frame rack, replace a couple panels anyway. The tower is into the fuel tank. Any other damage, probably most likely, paint and reassemble the car. Yes it will need an alignment. Probably a strut... and who knows what else.
Old 01-06-2011 | 07:58 PM
Makmov's Avatar
Makmov
You didn't take in account the headache factor or unknowns. I'd say 10-15k, and only have I inspected it personally.
Old 01-06-2011 | 08:00 PM
Makmov's Avatar
Makmov
If I had to guess that was side impact and not vertical damage.
Old 01-06-2011 | 08:49 PM
jdistefa's Avatar
jdistefa
Peter - is this a US car that has already been imported into Canada?
For $25k - even if the car is already in Canada - I would look for a straight unmolested car with a well documented history in the US. Even though you'll have to import it, duty, paperwork, etc... my bet is that you'll end up ahead compared to dealing with both known and unknown hassles with this car.
Old 01-06-2011 | 08:57 PM
dave morris's Avatar
dave morris
The owner doesn't know how the damaged had happened.
He thinks that he may have hit the curb hard or might be damaged over time by improperly lowered suspension.
Very hard to believe.
Old 01-06-2011 | 09:22 PM
CorrdoBrit's Avatar
CorrdoBrit
Exactly. A jolt to cause that much damage would have knocked a few fillings out of his mouth. Unless he wasn't the driver he knows precisely what happened and when.
Old 01-06-2011 | 09:33 PM
jdistefa's Avatar
jdistefa
Why not buy Jford's car here on Rennlist? It's a helluva car with a very rare transmission.
https://rennlist.com/forums/7485461-post1.html
Quick Reply: Chassis frame damage near suspension mount
