993 Forum 1995-1998
comfort blinker
Old 01-05-2011, 09:07 PM
Greg H.
Greg H.'s Avatar
Default comfort blinker
Anyone installed one of these in a 993? I'm going to do it, but if someone has already figured it out I won't reinvent the wheel
Greg H.
Old 01-05-2011, 09:10 PM
User 122821
User 122821's Avatar
I love that feature on the Audi.
Old 01-05-2011, 10:07 PM
C2Cab95
C2Cab95's Avatar
I have that feature on my GTI... when I drive other cars, I get caught just doing the one blink lane change. I never thought to search on adding this feature. Do you have a link?
Old 01-05-2011, 10:21 PM
ilko
Agent Orange
ilko's Avatar
IIRC somebody posted about this over the summer. ECS Tuning has a kit that *might* work on our cars. We need a guinea pig, who wants to try it first?
Old 01-05-2011, 10:48 PM
L741_993
L741_993's Avatar
This is a great feature. Here is the ECS kit: http://www.ecstuning.com/Search/Turn...omfort/ES8792/
Does anyone have a wiring diagram for the Audi or VW, it should be easy to duplicate for the 993. I'm up for the challange to make it work.
Here is a diagram that may work:
http://e31wiki.org/wiki/One-touch_turn_signal_module
Old 01-06-2011, 01:22 AM
Greg H.
Greg H.'s Avatar
I have installed the esc kit in my Audi B5 S4 (which is what got me thinking about putting it in the 993). The kit is a VW OEM part, by the way, that is plug and play on B5 Passats and Mk 4 Golfs. On VW/Audis it splices into the hazard switch wiring. The hazard switch might also be the turn relay since it makes a racket when you signal.
Here is a picture of the comfort relay with diagram.
As far as I can tell from my Audi wiring diagram:
#2 - rear left turn signal light
#5 - rear right turn signal light
#8 - turn signal switch
#6 - power
#4 - ground
I don't understand how it knows which direction I signal with only one lead to the turn signal switch. Maybe someone can interprete that diagram on the relay?
Greg H.
Old 01-06-2011, 11:31 AM
MarinS4
MarinS4's Avatar
Greg you have a B5 S4? Your stock just went up in my book!
Old 01-06-2011, 12:11 PM
Greg H.
Greg H.'s Avatar
Originally Posted by MarinS4
Greg you have a B5 S4? You stock just went up in my book!
Imola Yellow Avant.
Greg H.
Old 01-06-2011, 01:26 PM
Akerlie
Akerlie's Avatar
check my thread here : https://rennlist.com/forums/993-foru...rt-module.html
I ended up splicing the relay into the wire bundle underneath the steering column.
I just bought the VW relay (part no 000-953-227 if I am not mistaken) and made up the wiring myself, no need to buy that expensive original wiring kit.
Here is how it should be spliced into the original wiring :
Color VW wiring kit / Number relay / Color 964/993
Weiß-Grün / 49a / SW-WS-GN, d.h. Schwarz-Weiß-Grün
Grün / 49R = R / SW-GN
Weiß / 49L = L / SW-WS
Braun / 31 / BN also Braun
Schwarz-Weiß / 15 / SW
Old 01-06-2011, 01:32 PM
Greg H.
Greg H.'s Avatar
Akerlie -
Do you remember what wires you spliced into?
Greg H.
Old 01-06-2011, 01:37 PM
Akerlie
Akerlie's Avatar
I took of the steering wheel and found them in the bundle under the column, did it that way since my flasher relay which on my car is located behind the oil gauges did not have all the wires required (only 3 wires go to the flasher relay on my car).
Edit : BTW if you want the original wiring kit its VW part number is : 000-998-229A
Old 01-06-2011, 01:47 PM
Greg H.
Greg H.'s Avatar
Thanks - I'll give it a try in the next few days with the relay out of my Audi.
Greg H.
Old 01-06-2011, 01:51 PM
Akerlie
Akerlie's Avatar
You are welcome I was also hoping it would be a plug and play thing as when i added the comfort blinker to my Audi A2 but unfortunately I saw no other option than to splice it into the existing wiring.
Old 05-16-2012, 12:37 AM
Rust911
4th Gear
Rust911's Avatar
Im new to the site, specifically was looking for this exact modification. I have it on my audi and the wifes volvo, great feature. Any pictures of the mod by any chance?
thanks.
96' 993 C2
03' A4 Quattro
07' XC90 Volvo
'92 Ford Explorer
Old 05-16-2012, 12:45 AM
Resident Sicko
Resident Sicko's Avatar
Never knew this had a name...our 2012 Focus and 2012 Fiat 500 also has this feature.
Quick Reply: comfort blinker
