for sale: 993/964 rs clutch and flywheel
That looks to be all the parts needed to do the LWF/RS clutch swap, with the exception of the shorter flywheel bolts. It's a good deal as the retail (pelican) on that stuff is up north of $2000....
Sunset will sell you all the parts in this picture for $1700?????
![](http://forums.pelicanparts.com/uploads18/DSCN23351293734475.jpg)
Did you notice that the starter ring gear, throw out bearing, pilot bearing, shift fork thingy, boot, etc...There's even a clutch slave cylinder.
I've no affiliation with the seller btw.
Thank's for all the interest, I answered all questions on Pelican, it's more than what you need to do the swap, I have the bolts as well, only thing missing is the Flywheel Pilot Bearing ($6.50 from pelican) I reused it on the Tilton I bought from a member here on rennlist. I recommend using a new slave since mine is older than the clutch or use what's on your car. If I remember correctly I bought it last year for $1800 from pelican, if somebody knows the acceptable thikness of the clutch, I can measure mine so everybody has an idea the wear. Thank's.
also sent you a pm
