Another heated seat question
I really like them over the stock 993 seats. To me, they have more support and better feel. By the way, I am loving the 996 seat heaters, they heat up in about 30 seconds and the 'high' and 'low' settings are perfect. I think I paid $700 for this set I found on ebay. The prices for nice 993 seats get a little crazy, and they are hard to find in really nice condition. I am assuming there are lots of 996 seats out there. If you search, you will find some good threads on putting 996 seats into a 993. When people see mine, they think they are stock 993 seats. Again, mine are heated, but only have the power seat-back. The front-to-rear slide is a 'basket-handle' lever and the seat height lever is on the side, controlling a pneumatic shock. I am pretty sure that full-power 996 seats would also work fine, but my main objective was black with heaters and headrest crest. Here are a couple more pics...
And to Paul K, you are right, you can get pretty good money for your 993 seats, I got $600 for my cashmere, partial leather seats, so it was a cheap upgrade
Center console is probably where my switches are going as well, depending on what heating and what seats I end up with.
600RR, what type of heating did you put in and how? I assume full seat reupholstery with aftermarket heating elements?
Mike S. Like a DA I didn't research the heaters until after the install. Typical of my mod approach! In any event, the one installed by the shop is not as warm as my Cayenne OEM. Here are several links that include the HEIZGERAT SETZT which seem to be good:
http://www.heatedseatkits.com/heatedseatkits/index.html
http://www.sportsimportsltd.com/seat...FSdtgwodRVz4og
Yep, I have one of these carbon dual heater pads. Bought it many years ago with intent to put into comfort seats of my first 993. Started taking teh seat apart, saw the design where foam is stitched to leather cover and quickly decided that it's not the right solution. This thought has since been confirmed by a couple upholstery shops.
So if one re-covers the seats, the pads can be installed easily and efficiently. If they go into existing 993 seats - not so much.
