Tweeter cover - DANG!!! Help!
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
Well, stupidity certainly has its price. I am just trying to minimize MINE...
I was installing back the cheapo (well..) plastic tweeter cover on the passenger door, and, naturally, one of the tabs broke...![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
As it turns out, this is about $40 at Pelican; and, there is no guarantee that this is not going to happen again. I mean, I am a trained professional...
Thusly... DOES ANY ONE HAVE ONE TO DONATE/SELL/USE AS A X-MAS GIFT TO A FELLOW PORSCHENISTA?
The actual part No. is 9936455020001C.
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
If I do, you can have it
This is only the plastic housing, right?
OK, have one and it is in tact.
It's in a USPS flat rate box, ready to go. PM me your address. or better yet, email it to fdmotorsports@comcast.net
As long as the postal workers don't crush it we should be in good shape![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Also... how about some photos of your cab?
I looked at the pictures that you put in the write-up and it would seem that I have taken a totally different path... I ripped out the Nokia amp and that's where the cross-overs will go (I ended up with the "old-school" MB Quart's RVF216)...
You show that you used a press-board support for the 6.5" speaker... I just screwed it to the cover panel... You think this is going to affect the sound?
If I and/or the car survive the experience... I dunno; don't want to encourage people to follow in my steps. I used 6.5" 2-component speakers with passive cross-overs and an aftermarket 4-channel amp (which does not fit in the Nokia's space) - so, trunk install and all that.
I think that the easiest way is to just drop 5.25" component with a coaxial tweeter and be done. Maybe a small amp. I do like the Kenwood head unit tho (KDC-X794).
I am wondering how the whole thing will sound.
There is absolutely no problem installing 6.5" components,. I have Focals in my car. Used plywood to cut a shape to mount the woofer and crossover on each side. Currenlty running without an amp, but will eventually add small efficient amp under the passenger seat.
Having said all that... it's not a car for sound, especially a cab like mine.
Instead of plywood, I just screwed it to the panel to which the Nokia sound box (I have a HiFi option) was attached. I am wondering - why use the plywood shape?
Speakers need two things to work properly - separation between the back and the front (1) and sturdy mount (2). When you mount a speaker to the door, you do not get proper flat mounting surface. Nor do you get separation of front and back as the speaker does not completely cover the hole ans sits a bit crooked in there (at least mine did and I also have Hi-Fi option). I tried both mounting to the door and mounting into the black Hi-Fi enclosure. Did not like it either way.
Cutting a simple shape out of plywood (not my idea, saw it here on Rennlist) cutting a hole for the speaker in it and mounting both speaker and crossover to it is such an easy and elegant solution that I wouldn't even consider doing it any other way.
Little things like trying to kill resonant frequencies, maximize enclosure volume, etc are separate issues, but are helped by plywood as well.
Also... how about some photos of your cab?![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
