Engine drop epidemic
Thanks to Falcondriver I have a barely used LFW and clutch, and thanks to FD Motorsports I have new parts to install it! Put new TO and pilot bearings in even though the others were fine. New bolts seals and release shaft parts also came from Mark, at prices better than even the discount dealers. Now I just have to wait for the locally sourced Olista grease to show up (must be made of crushed unicorn horn's as long as the dealer is taking to get me a small tube).
Lot's of projects in addition to the RSCS clutch. Injectors getting cleaned, clean up engine, trans and engine bay, different rear control arms with ERP bushings, DME chip, SAI delete, t/c gaskets, paint fan and housing, and then re-corner balance and align. That should keep me busy for most of the winter.
Thought I would show my engine lowering setup. I have seen posts with multiple jacks half a lumber yard and some of them looked kind of scary.
I used a Craftsman Pro aluminum ATV jack ($179) with a little bit of lumber down the engine seam (shims under exchangers are just to balance the engine, no weight on them). Also a scissor type transmission jack ($50 ebay score) under the front crossmember. The ATV jack came with 2" risers that matched the lowest height of the scissor jack perfect.
This setup was rock solid, safe and rolls really easy. I dropped the engine and trans without help and it was, dare I say, easy. No issues at all.
Not quite true, 1 issue, I mis-measured my height on the jackstands by 1 1/2 inches. The ISV and MAF wouldn't clear the rear of the car, but 2 hose clamps and a few seconds later and it rolled right out.
Sorry for the rambling post, just excited to have winter projects !!! Thanks to those Rennlisters before me that showed the way with great DIY's.
Jack setup:
Not quite enough room:
Out
Lot's of cleaning to do.
The engine seems balanced on the stand, so I plan to put another jack under the diff, unbolt the trans and roll the engine away.
http://www.harborfreight.com/1000-lb...art-93116.html
Also left the rear bumper cover on. I mis-measured also. But, my ISV fit through the exhaust tip hole!
I think you should let me store your Fister Stage 2s in a warmer climate for you until spring.
To my surprise I had none.
I was also surprised how easy it was to get the bumper off, looking back I am glad I did because as easy as it was to roll my jacks, I was able to move the engine/trans back and to the left as I lowered giving plenty of clearance at the driveshaft/starter. I can see where clearance would suck if your jack setup didn't roll sideways and back easy.
A mid rise lift is in the works, friend of a friend is going to sell his and I am first in line. I have access to 2 post lifts @ work but wanted to take my time at home.
I really don't mind working from the floor, I didn't even fire up the air compressor, hand tools only (I got done and realized I could have saved time with my air ratchet but old school is more fun.
Thanks for all the inspiration guys!
Have a Happy Holiday!
My wife is convinced I am going to reassemble the car in the basement so I can spend all winter with it.
Thanks again Rick.
If anyone has a ATV lift or an engine stand they will loan out, please PM me!
