Help - Lip Seal Spring-less
Hi,
I am fixing a vacuum leak in the vario-ram flapper assembly and need to replace a Spring-less Lip Seal
(.437" inner diameter)
(.473" outer diameter)
(.116" depth)
![](http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?command=show_parts_image&Headers_Id=38734&Line_Item_Number=17)
This part of the flap housing 993 110 061 03 - Porsche only sells only the entire assembly available only in Germany appox $200 (Sunset)
It pains me to spend $200 for a $1 part.
Any help or suggestions are appreciated.
Thanks!
(.116" depth)
![](http://farm6.static.flickr.com/5285/5281745408_4df2003c39_m.jpg)
Thanks!
This might help:
http://www.sealanddesign.com/categor...8/V_Seals.aspx
you can also do a Google search for 'shaft seals' and get lots of results.
