993 Forum 1995-1998
RUF Wheel fitment - 11" rears
Old 11-19-2010, 04:28 AM
Mike J
Mike J's Avatar
Default RUF Wheel fitment - 11" rears
Through a contact, I jumped on a set of 19" RUF wheels ("Classics"), and it turns out the fronts are the same I am running on my car now, but the rears are not the 10" ones that fit fine, but the 11" ones. These wheels do fit OK on 996's, 996 Turbos/S's, and 997's, but do not fit on a NB 993.
The question is, will they fit on a wide body 993 such as a 993 C2S/C4S or 993 Turbo?
The specification on the rear wheels are 11J x 19H2, ET70.
Cheers,
Mike
Old 11-19-2010, 06:33 AM
J.A.W.S.
J.A.W.S.'s Avatar
maybe they fit on NB 993s using 5mm spacers and rolling the rear fenders...
i found a technical report for 19" RH AL-wheels in my archive that stated the following:
993 (200; 210; 221kw) - 911 carrera, carrera4, 911 carrera RS (coupé, cabrio) front: 9x19 ET52
(235/35ZR19-88Y) rear: 11x19 ET65 (275/30ZR19-96Y) needs rolling the fenders up to 10mm
Old 11-20-2010, 03:56 PM
Kevin Weidlich
Kevin Weidlich's Avatar
For a wide body 993 you would need at least a 20mm (to bring the outside of the wheel to where the stock wheel sits) but a 30mm-38mm spacer would put it more flush with the fender (farther out than stock).
Old 11-20-2010, 06:11 PM
Mike J
Mike J's Avatar
We are going to give it a try next weekend...will post the results.
Cheers,
Mike
Old 11-20-2010, 07:25 PM
CalvinC4S
CalvinC4S's Avatar
I had these same wheels on my 4S, you are going to love them with polar silver!
Old 11-20-2010, 07:48 PM
Mike J
Mike J's Avatar
I already have RUF's on my 993 Targa, with with the 11" set on the rears. These are another set that I acquired where the rears are 10". :-)
Do you have the 11" rears on your 993 C4S? How do they fit, and what spacers did you require?
Here is my car:
Cheers,
Mike
Old 11-20-2010, 08:06 PM
sanyata
sanyata's Avatar
I've got a set of 28mm H&R DRM hub centric wheel adapters brand new in the box if you need them.
Old 11-20-2010, 08:37 PM
CalvinC4S
CalvinC4S's Avatar
RUF Dallas sent me rear spacers with the wheels.
They fit tight with RS camber, but never any issues. I understand the 11" wheels to be designed to fit a NB RUF TT.
Old 11-20-2010, 09:13 PM
Mike J
Mike J's Avatar
i actually have a set of spacers with my original set of RUF's, but not for this new set. Not sure but I might be selling them since they are unlikely to fit on my existing car, but I am waffling a bit...
Sanyata, will let you know if I need the spacers, thanks!
Cheers,
Mike
Old 11-20-2010, 10:09 PM
Benton
Benton's Avatar
I just got back from the shop installing 19x11 ET67 997 Carrera Classics on my 993 with 285/30s in the back. Everything fits well with rolled fenders, and my car is probably a tad lower than RS height. I would probably have a problem with 295/30s. So, as others have stated, those 11"ers are NB wheels.
Old 11-20-2010, 10:20 PM
Magdaddy
Magdaddy's Avatar
love the clean look upfront...email question sent Calvin
Quick Reply: RUF Wheel fitment - 11" rears
