Need flasher location.....
Just installed LED signal/parking lights which created a fast blinking senario due to the lower resistance.
Purchased an LED electronic flasher relay which should resolve this.
The OEM flasher relay is not located by the passenger footwell hatch but appears to be behind the fuel/oil temp gauge on the left.
Before i start pulling gauges out of the dash is this DEFINITELY the way to access this relay ?
Um...I think it is is located behind the hood strut on the driver's side and is accessed from inside the trunk...Open your hood, turn on the flasher and reach back in there...There are two relays and I think it is the back one....WIth the flasher on, you should be able to feel the relay activating.
Check frame #12 on this thread https://rennlist.com/forums/993-foru...is-needed.html for photos.
