Congratulations! It will change your life in so many ways that you can't imagine.
Baby seat will have to be mounted using the seat belt but without the base (they are usually made to work that way in case you can't fit the base. Most likely you will want to use a Mighty Tite ratchet or replace the three point belt with an old style two point belt to make sure it is tight. If you have finesse, you can get the three point belt to ratchet and tighten down sufficiently.
Congrats! I won't lie to you- the first couple of weeks after bringing the baby home are terrible. Hang in there- the real fun is just around the corner. Now I can't even remember the days of sleeping in!
One downside to the 911 is that the rear-facing infant seat doesn't fit very well. My daughter started riding in the 911 once she was 1 yrs old (she is now 2.5). On the plus side, babies require lots of trips to the store to get formula, diapers, etc., so you should still be able to sneak in some seat time!
