Cranking the engine with ignition and fuel pump disabled.
I've never seen an operating engine that got rusty inside. One could debate that wear and tear from cranking it every couple of weeks when there is partial film lubrication is worse than just leaving it alone and doing it once in the spring. I doubt either will be detrimental to the longevity of the engine. Who knows. Its just something to consider. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
cheers,
mike
Ken:
That makes a lot of sense.![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Similar to stuffing raisins up one's nose to see how many fit in there to set a new world record for someone with room temperature I.Q.
Not sure what the difference would be between just cranking vs starting up, same parts are moving in a NA engine. Didn't think you can get oil flowing any faster by cranking. I guess just avoiding a few seconds of little higher rpm with the engine idling? Now if you had turbos that started turning with the engine starting (vs not turning with just cranking) while waiting for the oil to start flowing, I would understand but still doesn't take much time for the oil to start flowing to the turbos and would only do this if I was swapping out turbos or draining the sump tanks off the turbos...
I store my car for 3 months, and whenever I would fire it off, I used to hear a clacking ( valve lifter?) for about 5 min, then it would go away. This year, I pulled the DME, and cranked, got some oil pressure, and then fired it off. No clacking. So I am a believer!
Yes, Greg, that's exactly what happens.
Building up pressure without ignition or fuel is standard procedure after a rebuild and the same principle applies after a long storage.
It doesn't take long, about 3-5 seconds of cranking to prime. Replace the DME relay and start without clacking or rattling.
In climates that have a lot of humidity like ours here, I like to turn the engine over occasionally during winter storage to prevent the slightest chance of internal rusting.
It's very simple: Anyone who doesn't want to do it, don't do it.
I also like to position the engine so that the valve springs aren't depressed all winter long...that is doable on some engines depending on number of cylinders and configuration.
I was visiting a shop last year, and the head mechanic showed me some 911 barrels that were on an engine that was not started for a year. The car was sitting in an open carport in our Vancouver area, which is known of course for rainy and humid weather. The inside of the barrel had a very light coating of rust, he claimed that the piston in that barrel was close to the bottom, and that the air that was pulled into the barrel had enough moisture to cause some damage......
