993 Forum 1995-1998
Atiwe steering wheel install
Old Nov 6, 2010 | 02:46 PM
Cristel993's Avatar
Cristel993
Default Atiwe steering wheel install
After reading that the 'M433' 993 option code relates to the fitting of an Atiwe steering wheel, I installed a 340mm Atiwe Silberpfeil today (Raid/FVD/Ruf style, but Atiwe branded), which was pretty straight forward following instructions I found on RL (as installation instructions are in German only):
https://rennlist.com/forums/993-foru...it-on-now.html
In addition I had to fit a new airbag plug, which was also easy following the (thankfully) English instructions, which were included with the Raid boss adaptor. No welding needed, only some wire cutters, pliers for crimping and insulation tape. The airbag light goes out successfully, both horn buttons work and I made sure I adhered to the tightening torque requirements (thanks Graham):
Airbag retaining screws - 10Nm (7ft/lbs)
24mm nut - 45Nm (33ft/lbs)
Took her for a quick spin this afternoon and it really does make the car feel different; there seems to be more steering feel, certainly more comfortable to hold, easier to get in and out, with no knee rubbing when driving and the extra 'girth' feels brilliant. Bigger isn't always better?!? Aesthetically, for me it's a big improvement on the standard bus like four spoke.
Old Nov 6, 2010 | 04:24 PM
csertich's Avatar
csertich
Looks great! So much nicer than the stock wheel.
chuck
Old Nov 6, 2010 | 04:44 PM
ginch's Avatar
ginch
Where would someone buy this wheel? Damn that looks great!
Derek
Old Nov 7, 2010 | 10:19 PM
sml's Avatar
sml
these look pretty similar if not the same ...
http://www.porscheshop.co.uk/acatalo...sche_raid.html
Old Nov 7, 2010 | 11:02 PM
Franz993's Avatar
Franz993
I have the same exact wheel but with FVD badge. One of the best upgrades you can do.
Old Nov 8, 2010 | 03:09 AM
Mike J's Avatar
Mike J
Yup, got one too...not cheap but it makes the car feel quite different, more responsive. 340mm is quite small, its amost PC-gamer small, but its also fat and fits your hands well. When I drive a "normal" 993 now they feel very awkward, with the large wheel... :-)
Old Nov 8, 2010 | 05:33 AM
Cristel993's Avatar
Cristel993
Derek
You can buy one from Gert at Carnewal with the Raid badge:
http://www.carnewal-europe.com/cpx_p043.htm
Might be worth asking him if he can source them with the Atiwe badge if the branding matters to you (linked to the M433 option code).
Sam
Old Nov 8, 2010 | 09:50 AM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
I have the exact same wheel with the Raid badge (badge is gone though). Picked it up thru Gert when they were on sale. Love it, it just feels right.
Old Nov 8, 2010 | 11:46 AM
KJO's Avatar
KJO
....and, for tall folks, it gives significantly more leg room under the wheel -- you don't need to fit the wheel between your knees.
Kevin
Old Nov 8, 2010 | 12:18 PM
JPS's Avatar
JPS
340mm...what is stock? How much smaller is this one?
Old Nov 8, 2010 | 12:25 PM
EckFe1's Avatar
EckFe1
JPS,
stock is 360mm
Old Nov 8, 2010 | 12:28 PM
cabrio993's Avatar
cabrio993
Love my RAID Daytona 340mm wheel as well. The car just feels "right" with it. See my avatar for picture.
Old Nov 8, 2010 | 01:05 PM
bart1's Avatar
bart1
Stock is 380. UNless you have an RS - it's 360. And the suede Cup wheel is 350.
Old Nov 8, 2010 | 03:47 PM
Slow Guy's Avatar
Slow Guy
Veteran: Navy
Kevin
It also brings the wheel 20mm closer to the driver so those of us with the seat all the way back don't have to drive with arms out straight.
