Do you guys remove battery when storing for winter??
Im debating if i should remove battery or not. And does the porsche trickle charger work if battery is out of pcar?
Thanks.
Thanks.
No need to remove the battery. Just plug in the Porsche Maintainer and it will float the battery till spring. Works perfectly. The only thing I do in the winter is kill the clock (fuse) and take al ook at the battery for any signs of overcharging.
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
Porsche, Schumacher or other battery maintainer will do the job. My battery is 12 years old and is on the maintainer if I let the car sit for more than 2 weeks. Onboard is easy...search for the info as it has been documented many times. Remember to shut off the trunk light by closing the latch on the hood so the trunk light goes out!
Cheers!
Cheers!
I leave the battery in all the cars I store for the winter, and connected to a battery tender. They're usually stored for 6 months, give or take, and they start right up every time in the Spring. Been doing it this way for many years.
Cheers.
Cheers.
Just don't try to add fluids to a sealed battery...or do but film it for us please.
Ok silly question however does the battery tender just get plugged into the wall and left there? Do you close the hood completely or just partially click closed? And then you still put the cover on over top? I've always just removed the battery for the winter and kept it inside the house!
4 me:
Battery tender, Sta-bil in the fuel, stored in gear with ebrake off, a few moth ***** near the wheels, under two covers, and only started if I have time enough to let it get fully warm before turning off.
I put my cover over the car while it is connected to the CTEK charger.
