Switch for fan override mod?
Lifetime Member
Lifetime Member
The only anomaly is that the switch is normally kept pulled out out, and pushed in to active the oil cooler fan manually. Haven't made the light in the switch work either, but haven't really tried.
Manual control of the fan really helps when stuck in traffic or waiting in the autocross staging line.
I used the tail activation switch on the console to work my garage door opener. (Also on P-Car.com)
Just an update on the switch for the middle position in the console:
I got a set of 944 switches from the bay and it confirmed that there is a better option than the hazard switch that does not require any dremeling. It is the rear windshield wiper arm switch for a 89 944 and a 1:1 replacement with the blind switch; part number 95161311300 which is cheaper on the bay than the recommended hazard switch.
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
They other advantage is that the switch is "electrically closed" (normal operation) in its base position and is aligned with the other switches. You can clearly see if you are in bypass operation after you operated the switch.
Here is a pic. I have not cleaned the switch but Aerospace 303 will make them look the same:
![](http://i482.photobucket.com/albums/rr186/e9stibi/P1020383.jpg)
The rest of the installation should be easy. I will go for it as soon as my new stereo (Kenwood BT900) arrives next year.
I cut the emblem out from a sheet of vinyl decal by using a xacto-knife.
e9stibi, is the finish different from the other switches or is it just the photo? I used a 944 emergency switch. Removing the taps so it would fit was a 60 second job, no big deal. What I would like to do is figure out how to wire it so the switch's light would come on when the switch is activated.
"I used a 944 emergency switch. Removing the taps so it would fit was a 60 second job, no big deal. "
Me too.
" What I would like to do is figure out how to wire it so the switch's light would come on when the switch is activated."
Chuck W.
Me three. I didn't think about lighting it up. Hmmmmmm.
I don't mind the orientation of the 944 switch but I might have to get out my nail polsh,,,, uh, I mean my wifes nail polish remover and the family xacto blade.
chuck
Me too.
Chuck W.
chuck
The finish is the same but the switch is older and I think the donor car was not garaged all the time which caused some fading. Not a big deal and with 303 this will be ok. The switch is not lighted. Just a basic "on/off" switch but this is exactly what I wanted. in summary, for the people that like the light: go with the hazard switch.
