Moton setup help - what else to get?
I bought new Motons with the recent group buy, and trying to figure out what else to get to complete the suspension setup.
I've read plenty of the threads but I just can't get my head around all the parts and what could/should be upgraded. I currently have PSS9s.
Here what Stever Weiner recommended in a previous thread:
1) Moton double-adjustable shocks with a custom spring package. (Clubsport or Motorsport)
Done
2) ERP monoballs in the front A-arms and all of the rear suspension links.
I often read "monoballs everywhere" but can't figure out where everywhere is!
Part numbers? Which are most important?
3) ERP rear adjustable toe and rear kinematic links.
Are both important? If one had to choose which to get?
4) EVO front uprights
Part number? How important are these, relative to the other parts listed here?
5) EVO/ERP bump steer tie rods
6) Front & rear camberplates/monoballs
Most good camber plates include/are monoballs correct? e.g. "ERP Rear Upper Shock Mount - Monoball Set" and "ERP Front Camber Plates Set".... what about the Rennline cambe plates?
Any advice/clarification is much appreciated!
Thanks in advance,
Done
Thanks in advance,
RL Technical Advisor
Rob,
JMHO,.......
To your list:
2) Monoballs in the front A-arms (track-only), monoballs in the rear lower control arms, again, track-only.
3) ERP rear toe-links are a MUST as that controls (stabilizes) unwnted toe changes; the key to making the rear end feel "buttoned down". ERP kinematic links allow a great range of adjustment and thats important with a lowered car. Further, this allows one to "bump-steer" the rear suspension and thats one of the differences between an average or a really sharp handling 993.
4) EVO uprights & tie-rods MUST be installed together as thats the only way you correct the bump steer that occurs when these cars are at RS ride height (or less). Remember, Motons are shorter than OEM (or PSS-10) shocks and they must sit at a lower ride height.
6) Camberplates do include monoballs and need to be installed at all four corners when using Motons. This is due to the shorter shock shafts that aren't long enough to extend all the way through the OEM rubber mount. After all, those rubber mounts simply cause a loss of static camber in a corner and thats the main reason to get rid of them, anyway,......
Camberplate/monoballs all differ a little in design and the quality of the spherical bearings. This isn't the place to cut corners and use cheap ones as they will simply require more frequent replacement.
Hope this helps,
Naturally, I can provide whatever items you might need,...
JMHO,.......
To your list:
Hope this helps,
Done
Thanks in advance,
Done
Thanks in advance,
3)you can use ERP links which come w/ monoballs or RS KT links w/ a Tarret /Rennline toe link, both are important, do them both, don't do a piece here and a piece there. do it all w/ a track alignment as the last step
4 & 5) 993RS uprights aka EVO ,
993.341.157.81 Wheel carrier /L
993.341.158.81 Wheel carrier /R
993.347.031.81 Tie rod x2
999.053.041.03 front wheel bearing x2
993.606.405.00 abs wheel sensor x2
6) f/r(you need both ends) monoball/camber plates you can use ERP or Rennline
Thanks for the advice and info. I forgot to mention that this is a track-only car. Keeping it registered to make gas runs for now.
Looks like "all of the above" is recommended/advised, correct?
Steve, I'll definitely be in touch
Yes, Except that the ERP arms add an extra element of complexity. A particularly knowledgeable setup guy is mandatory, if you just replace the bushes w/ monoballs in your stock arms it's a whole world easier to set up.
The only arm that's worth buying is the rear toe links w/ locks, most of us use Tarret, Rennline just recently came out w/ a version and ERP are all good
Bill, sorry again I'm still fairly suspension-component naive.... but I don't need to replace the stock A-arm when I get the above-mentioned ERP links/bushings right?
if you buy ERP links they come w/ monoball inner ends but you can also just buy the replacement monoball inner ends for the stock arms
I wanted all new components, so I bought RS arms and hardware. RS was no more expensive than stock and came w/ harder rubber bushes. It has all worked out very well and even though it's mostly a pure track car I don't see the need to go to monoballs except where they already are, shock tops and toe links. The setup I have now compares well w/ monoball equipped 993s that I have been in w/o the maintainance issues. Mono ***** are wear items
