View Poll Results: How often do you change your oil?
3k miles
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
30
18.52%
5k miles
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
74
45.68%
7k miles
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
30
18.52%
3 months
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
0
0%
6 months
![](https://rennlist.com/forums/images/polls/bar6-l.gif)
![](https://rennlist.com/forums/images/polls/bar6.gif)
![](https://rennlist.com/forums/images/polls/bar6-r.gif)
9
5.56%
9 months
![](https://rennlist.com/forums/images/polls/bar1-l.gif)
![](https://rennlist.com/forums/images/polls/bar1.gif)
![](https://rennlist.com/forums/images/polls/bar1-r.gif)
19
11.73%
Voters: 162. You may not vote on this poll
Oil change poll! How often?
#61
This one at 16k will be my "base" analysis for all future oil changes. The next change will compare these numbers to the new ones, and so forth. That's how you use an analysis to determine OCIs for your specific motor, oil, driving characteristics, and environment. The comparison over time allows you to properly assess the OCI periods.
I only posted the report pdf because Alex asked that somebody post one to see what they look like.
Alex: All they say about their testing is that it's based on ASTM methods. Spectral Exam: D5185; Flash Point: D92; Insolubles: D96; Viscosity: D445.
But if you contact them, I'm sure they'll give you the details. From what I understand they started out doing oil analysis for the aviation industry.
fwiw, Blackstone isn't the only lab around, but it's probably by far the most convenient to use.
#62
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Oil analysis are useful for a couple of things 1) when to change your oil especially when the cost is high as with industrial equipment with lube systems having large volumes 2) determining the condition of the engine 3) predicting a failure or end of life
#63
Having spent 15 years in an electrical standards lab (microwave), we tend to question measurements...and so should anybody. Just as you should question HP gains from a chip company or any other claim such as battery charger claims
. But I do understand that it is uncool to question anything these days...as in how dare you.
For $25 I expect accurate results considering the thousands of reports they pump out in a year. If it isn't accurate, it is of no use...sort of like a $25 torque wrench.
#64
ZnDPP is talked about a lot but not one single article I have read tells me what quantity is necessary in oil. How many ppm do we need to prevent wear?
Furthermore, I think I read that it is used as the final line of defense when the oil film has broken down.
#65
http://www.lnengineering.com/oil.html
#66
#68
BTW, I've come across that article before. I have to read it again.
From that article:
Many Porsche repair shops have acknowledged that these newest SM and CJ-4 motor oils are not sufficient for protecting any Porsche engine, including newer water-cooled ones.
#69
Who is Charles, what is his background relative to lubricants testing and what tests have been done? Lubricants testing (long term, real world) is very time intensive and costly.
From that article:
So what is Porsche Stuttgart filling the new Porsches with?
From that article:
#71
I think we are definitely going to get a better run out of it this year than last, for sure!! I'm thinking about doing the oil change myself . . . this month is so busy for me, I just don't have a chance to run the car up to Eurasia in time. Will be a new undertaking for me, will see how that goes!
