View Poll Results: How often do you change your oil?
3k miles
![](https://rennlist.com/forums/images/polls/bar2-l.gif)
![](https://rennlist.com/forums/images/polls/bar2.gif)
![](https://rennlist.com/forums/images/polls/bar2-r.gif)
![](https://rennlist.com/forums/clear.gif)
30
18.52%
5k miles
![](https://rennlist.com/forums/images/polls/bar3-l.gif)
![](https://rennlist.com/forums/images/polls/bar3.gif)
![](https://rennlist.com/forums/images/polls/bar3-r.gif)
74
45.68%
7k miles
![](https://rennlist.com/forums/images/polls/bar4-l.gif)
![](https://rennlist.com/forums/images/polls/bar4.gif)
![](https://rennlist.com/forums/images/polls/bar4-r.gif)
30
18.52%
3 months
![](https://rennlist.com/forums/images/polls/bar5-l.gif)
![](https://rennlist.com/forums/images/polls/bar5.gif)
![](https://rennlist.com/forums/images/polls/bar5-r.gif)
0
0%
6 months
![](https://rennlist.com/forums/images/polls/bar6-l.gif)
![](https://rennlist.com/forums/images/polls/bar6.gif)
![](https://rennlist.com/forums/images/polls/bar6-r.gif)
9
5.56%
9 months
![](https://rennlist.com/forums/images/polls/bar1-l.gif)
![](https://rennlist.com/forums/images/polls/bar1.gif)
![](https://rennlist.com/forums/images/polls/bar1-r.gif)
19
11.73%
Voters: 162. You may not vote on this poll
Oil change poll! How often?
#46
Quinn/CAT, the heavy equipment guys, also do oil analysis. Most of their business is commercial fleets of land moving equipment and such, but they'll test anything. I used to go with Stavelely as recommended by Charles Navarro, but I have a Quinn location close to me, so it is easy to pick up the kits. They are also a little cheaper than Staveley, their results come back sooner in my experiernce, and their analysis kits come with a prepaid mailer and the tube to draw the sample, so there is nothing else to worry about.
http://www.quinncompany.com/parts-se...fluid-analysis
I've done virgin samples of the same oil at both places and the results are consistent, so I think either is a good choice.
I'm no expert on oil, so I'd be curious to hear from Charles or Steve W on this, but there are so many variables in usage that I would assume that periodic oil samples are the best way to figure out what a comfortable change interval is for each person's use. High temperature use (i.e. track days, etc.) can accelerate deterioration of the oil, but infrequent use and/or short drives on a regular basis can contribute to water contamination from condensation, so I think whether you use mileage or time depends a lot on how the car is used. No one answer fits everyone. Porsche's long intervals probably make sense if you use full synth and drive the car on a daily basis and get the car fully up to temp every time, but cars that are tracked, garage queens that go out infrequently, or cars that only ever see short trips which don't get the car fully warm probably require different treatment.
FWIW, I change somewhere around 4k miles or 1 year, the car gets used weekly and sees a handful of track days per year. I've done a number of analysis samples on previous fills, and what I found (with the Brad Penn) is that after an initial drop in the TBN and viscosity, things stay pretty stable and don't drop off much until I change the oil. I've never seen deterioration of the TBN to the point that Charles would consider a problem, and that includes a lot of hard driving.
-Ruben
-Ruben
#49
Team Owner
@Ruben,
I don't think daily use makes any difference. It's usage type. an engine which isn't used regularly but when used it used in a light duty manner (longer trips but no racing) will demand larger oil change intervals.
#50
#51
Regardless of how they are driven when they are run, very occasionally used engines tend to develop oil leaks and other issues as well. Forgetting about oil change intervals, engines used more frequently tend to be happier. Their owners too.
-Ruben
#55
Team Owner
Maybe. Anyway, my point there was mainly regarding whether miles or time is the appropriate measure. 15k miles might make sense if the car is driven every day, but for some people here 15k miles might be 5 years worth of driving or more. In 5 or more years of light usage, I would definitely consider the impact of condensation in the sump tank on the oil condition, if for no reason other than seasonal temperature change, so time is probably a more important measure than miles for occasionally driven cars, regardless of usage type. For any kind of use, periodic oil analysis can answer a lot of questions about the condition of the oil for each particular person without speculation.
-Ruben
-Ruben
A car little used or not used (museum) dries out. All the seals shrink and this is what causes the leaks. Many folks bought the pristine examples when Harrah sold off its cars only to find they bought rolling junk - at least as far as running was concerned. They looked new (fresh resto) but they didn't run for squat. They had turned from automobiles into statues. Changing the oil would have made no difference. These are cars - they NEED to be used or they die.
I am all for periodic oil analysis. Given how much we put into these cars in care and money, this is VERY cheap to add.
#56
In any case, everyone looks at the same information (from Porsche, independent mechanics, and other owners) and comes to their own conclusion on what they feel comfortable with doing for oil change intervals.
These engines are pretty stout. As long as someone uses a good quality oil, chooses a reasonable interval based on their usage habits and changes both filters at the same time, and runs the engine regularly and properly, everything will be fine.
-Ruben
#57
Looking at the sample Blackstone report, I take it we're primarily interested in the section labeled "Properties" when assessing how the oil is holding up?
