this is CRAZY!- red seatbelts install
so I've been thinking about having red set belts (front only) put in my 993 turbo. I called my service coordinater at the local Porsche dealership to see how much it would cost to have their mechanic install the seatbelts (I do not know of a local qualified wrench)
the cost was quoted at $280. I told him I thought that seemed high as I heard it was about an hour of labor. He told me it was a big job as the belts need to be "reset" and calibrated. Supposedly there is some type of "explosive" in there that needs to be dealt with too. Also that the battery would have to be disconnected. I do not want to disconnect battery due to issues that then supposedly occur at emmissions testing time.
Does this all seem bizarre?
that's crazy talk to have them installed. i did red belts in my previous 993 and it was a very easy job. probably took about an hour with my (then 4 year old) son. i didn't have to disconnect the battery or reset anything.
Agent Orange
Bull****. I've taken apart those belts, there is nothing to be reset or calibrated. Especially if you're getting a new set. I can see how you may have to unwind and rewind a set that has been retracted all the way but even that is not a huge job. And there is definitely no need to disconnect the battery either. They are pulling your leg big time.
The explosive that he is referring to would be from the seat belt pretensioner. The pretensioner is used to tighten the seat belt in the event of a collision. It does this by using a small explosive expanding gas to drive a piston that retracts the belt and pulls it tight on the occupant of the seat. These have the potential to be dangerous to people in my line of work if not handled properly during an extrication. These first appeared in 2002 996's and newer - so this would appear to be another case of someone working at the service department of a dealer not knowing squat about our cars - there is no need to disconnect the battery and should not need more than an hour for labour (it should take about 10-15 min).
The Service Writer/Manager is an *** CLOWN. I have installed blue belts in my Rivi cab and Yellow belts in my yellow cab. I rolled my yellow cab with the yellow belts installed by me and they kept me alive. I installed both sets myself. A very easy DIY. He doesn't know what he is talking about.
Mike
Mike
From the model year 2002 Tech Book;
"For model year '02, all 911 models are fitted with belt tensioners and belt-force tensioners.
The pyrotechnic ball belt tensioner is combined with the belt-force limiter in one unit.
The threshold value for triggering the pyrotechnic belt tensioner is calculated as for the airbag actuation from the sensor signals for vehicle deceleration. The triggering of the belt tensioner during a frontal collision takes place together with the triggering of the front airbags.
During a rear collision only the belt tensioner is triggered.
The ***** are driven through a pyrotechnic propellant charge. This kinetic energy is carried over to the belt reel via a pinion. Belt slack is taken up by winding in belt.
Belt-force limiters
To avoid bruising and internal injury, the belt's pulling force must be limited to a bearable level. Further tensioning beyond a dangerous pulling force level is prevented. The belt can be balanced up to a certain length via a torsion shaft in the belt mechanism."
Yes;
Belt-force limiters
Belt-force limiters
Rennlist is a great place, and Chuck W. and Cactus (along with many others) are the sprit that put the 993 forum on the top of the list!
For Yellow belts, on my MOD list, I have only found a UK source.
http://www.carnewal-europe.com/cpx_p93050.htm
