993 Forum 1995-1998
Common 993 issues?
Old Sep 26, 2010 | 08:45 PM
M Fig's Avatar
M Fig
Is the seller paying for your PPI?
Old Sep 26, 2010 | 08:50 PM
Spidey 993
Guest
Posts: n/a
Thanks, I will check on those things as well. Not scheduled until tomorrow but just going through the list of items fixed/replaced either under or outside warranty.
Old Sep 26, 2010 | 08:57 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
It was the '95 993 that had the engine harness recall, also dual distributor vent hose added to keep ozone from deteriorating the internal belt.
Old Sep 26, 2010 | 09:02 PM
cpdjfd107's Avatar
cpdjfd107
Originally Posted by Van1
Dual Mass Flywheel can go bad causing a P300 series random misfire Check Engine Light. I had this issue but fixed it by installing a LWF.
Sorry to hijack the thread. I get a random CEL with random misfires. P300, 301,302, etc, my clutch is near the end of its useful life. I changed all the usual suspects, ISV, o2, MAF, wires, belts. I heard about the DMF causing this and I'm hoping it will be fixed when I upgrade to the rs clutch and LWF. My car has a low idle when warm around 740 rpm, it gets better with ac on as it bumps the idle up slightly. Did you also have this problem? How did you know it was the flywheel?
Old Sep 26, 2010 | 09:15 PM
Van1's Avatar
Van1
I did plugs, distributors, rotors, wires, etc, and would still occasionally get a CEL code P300, 301, 302, etc. Seemed to always occur when the car was at idle, fully warmed up, and waiting to go out for another DE session. When my clutch started to slip I replaced the DMF with a LWF and have never had the CEL come on since. That was a year and a half ago and 7000 mi. While not conclusive, I am convinced my DMF was bad.
I have never had a low idle problem.
Old Sep 26, 2010 | 09:26 PM
cpdjfd107's Avatar
cpdjfd107
If you aren't going to drive frequently make sure you invest in a battery charger/maintainer. These cars have a tendency to eat batteries when stored and not driven frequently. Make sure the charger has a float mode to avoid over charging.
Old Sep 26, 2010 | 11:00 PM
993c4_Toronto's Avatar
993c4_Toronto
Originally Posted by Kigiin
A few more...
- Windows switches are prone to break
FYI, I replaced all my window switches at the end of last season (that was November for me in Toronto). I was going to go OEM like I prefer to do with all parts but the $70/unit cost seemed crazy. I ended up getting $10/unit switches and they look fine and are still working like they should. Saved $190.
Old Sep 27, 2010 | 03:39 PM
skywachr's Avatar
skywachr
Originally Posted by Surfer2001
Excessive oil consumption, due to valve guides, rear tire wear, control arm bushings, driver door restraint mechanisms breaks, front & rear window squeaks, rear window cracks. Oil leaks.
Valve guide wear leads to top end rebuild. $8,000+ Some mechanics say a 60000 service on a 993 is a top end rebuild though that hasn't been the experience of many here. You never know of course so you should always be prepared for that possible expense.
0
Old Sep 27, 2010 | 04:02 PM
TRINITONY's Avatar
TRINITONY
Old Sep 27, 2010 | 06:14 PM
vaujot's Avatar
vaujot
Window switches tend to break? Really? Never heard that one before.
Old Sep 27, 2010 | 06:29 PM
944/951guy's Avatar
944/951guy
Most common 993 issue is........ Everything else you own (Cars, house, hobbies, ect..) goes to crap once you buy one because of the time you will spend driving it and modding it!
Old Sep 27, 2010 | 06:54 PM
Spidey 993
Guest
Posts: n/a
I won't be going there. There's already a closed thread and a ridiculous long thread still open on this subject.
However, if you really want to know...........
Old Sep 27, 2010 | 10:42 PM
Spidey 993
Guest
Posts: n/a
Closing thread, got what I needed. Thanks for the responses and help.
