ducktail on cab brake light???
Hello, all, I am considering putting a duck tail on my c4 cab. I asked a while ago if anyone had pics and no one responded so maybe I'll be the guinea pig here. I have the basket handle 3rd brake light obviously due to it being a cab. I'm assuming I won't put the basket handle back after duck tail install, so I guess I don't really have an option and will be without a 3rd brake light. Does anyone see a problem with that? And any recommendations on whose duck tail has the better fit/quality. I see Getty designs which FD Motorsports is using and there is a duck tail on Ebay right now from rennspeed motorsport. Any ideas are appreciated thanks guys.
However, if your car is lowered, with all the SUV trucks running around, having a 3rd light may help you to avoid a rear end collision.
IIRC it's a federal law. I think if your car came w/a 3rd brake light from the factory, it would be more than 'frowned on' if you removed it. Having said that, the chances of law enforcement knowing that your car came with a 3rd brake light from the factory are probably slim to none, don't you think? Especially if there's no trace of one ever being there. Of course, since the law, I believe, started in 1987, if you were pulled over by a bright individual that knew the law and he figures out that your car was manufactured after '87 and he notices you don't have one ... you could always say it was a european delivery and claim the 5th, except if someone rear ends you, then your pretty much SCREWED.
I never had any problem on my cab when it had the turbo tail (have since gone back to the stock decklid with the basket handle). That said, I have also been lucky and not been sited for failure to have a front license plate, despite being required here.
So for the rest of people on here that had basket handle 3rd brake light and went to a duck tail, what are you guys doing? Did you move to the rear window brake light or are you just without one?
I went with the high mounted rear window light when I put on my RS wing, but I have a coupe. Like mentioned above, I think lack of 3rd brake light might be frowned upon at inspection time. Have you considered something custom let (flush mounted) into the ducktail? Go to a junkyard and look for something to adapt. Are you capable with fiberglass? If I had a cab, that's what I would have done.
Maybe something from this page could be adapted? (1st and 3rd llights look closest option to me)
http://www.commandelectronics.com/th...ke-lights.html
Or, my best suggestion, here is a "how to" using watson's flush mount LED 3rd brake light. This would be slick with a duck tail on a cab or coupe!
http://www.replicarclub.com/Newslett...BrakeLight.pdf
http://www.watsons-streetworks.com/l...ke_lights.html #L58SMBT
Would be best to delineate what you personally consider a problem area.
Otherwise, at least 3 significant variables:
- Safety
- Aesthetics
- Legality
Any of the 3 could be a show-stopper (no pun intended), depending upon an owner's priorities.
Safety: generally, the more lights the better.
Aesthetics (appearance): absolutely your call.
Legality: I can only speak from experience, YMMV. Check with your authorities.
FWIW, for the years our 993s were produced, my research uncovered 2 general aspects: federal mandate (IIRC, three brake lights installed) & local enforcement (two of the three have to be functional where I live). I was told enforcement can even vary county by county
My current solution between safety, aesthetics, and legality is what's shown below: 2 additional brake lights in the center reflector. On an average day that means I have 4 operational lights (more than I'd have with OEM brake lights including a basket handle third brake light). On a bad day, if one light goes out, I still have 3 lights operational; 1 more than necessary to keep Johnny Law from writing me up.
Be safe, & good luck at finding the most convenient option that's best for you
From BobbyT's "Rear center reflector--unused bulb sockets?" thread:
I lucked out regarding convenience: previous owner installed my mod!
Regarding research, you may have found threads such as BobbyT's above-mentioned "Rear center reflector--unused bulb sockets."
Perhaps Crimson Nape Racing (Bob)'s "DIY Third Brake Light (95 model)" thread has inspiration for your ducky dilemma...
Chris-- Your main request sounds like a request to see other cabs with ducktails. Short of that, there may be more LED inspiration on the 356 forum, on RLer Q's impressive "retro tech project for my 356... LED brake light & indicator upgrade" thread ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
time for a little retro tech project for my 356... LED brake lights & indicator upgrade
i wanted everything covert when not in use....
so i opted for a centre mount brake light in the engine grille,
and indicators in the louvres
![](http://www.qplanet.org/q/356/356LED_01.jpg)
look a little deeper...
![](http://www.qplanet.org/q/356/356LED_03.jpg)
![](http://www.qplanet.org/q/356/356LED_04.jpg)
lights in action !!
![](http://www.qplanet.org/q/356/356LED.gif)
night time....
![](http://www.qplanet.org/q/356/356LED_05.jpg)
i am stopping now.....time to put down the ipod and look up....
![](http://www.qplanet.org/q/356/356LED_06.jpg)
the front received an upgrade whilst i was on a roll.
these were actually motorbike indicators
![](http://www.qplanet.org/q/356/356LED_07.jpg)
![](http://www.qplanet.org/q/356/356LED_08.jpg)
![](http://www.qplanet.org/q/356/356LED_09.jpg)
quite pleased with the results, particularly the brightness during the day !
Q
lights in action !!
night time....
Q
Many owe RLer Ilko for getting us interested in that mod ^^, thanks to his DIY photo tutorial:
Ilko-- Thanks for your DIY![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
"The 5 brake light mod: how to add 2 additional brake lights to an air-cooled porsche 911"
![](http://web.me.com/ilko/RSA_Black/How-To/Entries/2008/8/18_The_5_brake_light_mod_files/IMG_1864.jpg)
![](http://web.me.com/ilko/RSA_Black/How-To/Entries/2008/8/18_The_5_brake_light_mod_files/5BL.jpg)
EBay's "Porsche 911 993 Illuminated Reflector Bar—NEW." Starting bid $999.
Auction #160481307641, FS by 'automotiveauthorfreeinformation.' No affiliation.
If you call now, you can get the Forum discount price of $993; keyword: 'quack.' Operators standing by
+1 what curver lover has posted. If you know a real good body guy that works well with Fiber Glass he can integrate the 3rd brake light in the middle of the Duck Tail a la the Sport Classic duck tail. That would be pretty cool
Running the wiring would be Duck Soup!
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
Well it looks like putting brake lights in the center reflector will be my best bet. I was also thinking what Cahrera said and putting the current light into the duck tail, but I'd rather keep it for my original tail if I ever decide to change back. What about just putting the basket handle light back on the duck tail. Would that be too much going on in the rear of the car. Would I lose my "DUCK CRED" if I do something like that? Could anyone possibly photoshop a basket handle on a car with a ducktail, or a ducktail on a car with basket handle?
