moving wipers to passenger side?
How do you remove the relay any problems with doing this. 1.By removing the intermittent wiper relay you can park your wipers on the passenger’s side of the windshield. The only cost is your intermittent wiper feature is disabled.
[QUOTE=1991 porsche carrera 2;7899704]How do you remove the relay any problems with doing this. 1.By removing the intermittent wiper relay you can park your wipers on the passenger’s side of the windshield. The only cost is your intermittent wiper feature is disabled.[/QUOTE
I undid the nut on the wiper motor shaft, moved them to the passenger side, and have had no problems. I still have intermittent wiper function. Took a couple hours because the spot is tight but it was worth my clear view
[QUOTE=larpy;7900117]
I'm with Larpy, plan on doing this in the next couple of weekends. It's nice to see the front of the car, or at least some of it. It's a little tight but doable.
I undid the nut on the wiper motor shaft, moved them to the passenger side, and have had no problems. I still have intermittent wiper function. Took a couple hours because the spot is tight but it was worth my clear view![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
- open the relay cover.
- tug / wiggle the relay till it is removed.
- store it somewhere
- pull the wipers away from the glass
- fiddle with the wiper stalk till you get them to park where you like
- push wipers back against the glass
- if you can't find "just the exactly right position", you can always remove the wiper arms from the post then re-install to your liking.
you're done
it works for me and no scraped knuckles from the more challenging DIY.
enjoy!
