Ok, I've done a cursory search on this and seems that many have replaced their Becker CDR-210 with a modified CDR-220 in order to have IPod compatibility.
Has anyone here tried this adapter product? Does it work? Opinions?
The only proven way that I know of, is if you have a CD changer already wired into the stereo. You'll need to hook up the iPod through the RCA cables of the CD changer and keep a CD in the magazine to fool the radio into thinking that it's playing a CD.
The CD and CR-210 don't have an AUX input so the Blitzafe product in you link won't work unfortunately. If Blitzsafe made a box that fools the radio into thinking that it has a CD changer then you're in business. They might have, I don't know.
i posted my fix for a cr210 w/ a cd changer. i did this about a month ago and it works gr8! search for my posts. if you can't find it, i will link it for you or call you/pm you with the conversion. it was $30 or less if you have a cd changer. maybe you could find a cheap cd changer on fleabay if you don't have one. just let me know if need help good luck!
^This is exactly what I did. Very nice to maintain the stock look while having the ability to play the iPod.
I have never looked at the back of my CDR-210. Is there a CD Changer Port? I thought that was the limiting factor when trying to add modern day components. Hmmmm...
Looks like a good idea, if it works.
ETA: I looked at a manual online and there are instructions for "CD Changer Operations"
Reason: add comment
I just had Becker install an auxiliary input in mine.
And apparently they have a bluetooth module that should be available mid fall that will plug right into the input
Did you send Becker your stereo or are there local rep. outlets that can be contacted?
