Aluminum jack stands
#31
I am worried about looks when the difference is between the hockey puck or the esco flat tops.
the look of a welded flat top platform 'seems' much safer to me than my old hockey puck method, it might not, be but it sure looks safer.
I think that look gives me added benefit by making me feel safer while under the car, and for me the benefit was cheap compared to the extra cost.
but I am only giving my opinion and experience of moving from the regular jack stands and hockey pucks to esco flat top stands.
I'm perfectly fine with somebody spending less, especially when they come up with new ideas like the sanding block or crg53's method. but my experience tells me that once they get the esco flat tops they won't keep using hockey pucks.
#32
i use 2 jack stands and leave my jack up just for precaution. e.g. tonight i had my jack in rear location until placed jack stand in front location. eased off jack just enough to bare wt on front jack stand. then placed additional jack stand in front under suspension a couple of mm below and not touching (just in case for a backup). i keep the jack on bottom notch and therefore basically on floor so if it is going to FAIL is has to be the weld or frame bending. having said that, i am not sure i would ever feel totally comfortable under a car with just one jack (no matter the brand, country of origin or type).
still going to buy some flat stands...i think these will give me more warm and fuzzies??? guess we will see...
#33
OK, so its the safety aspect and how they are made, not the look. Gotcha!
I also have over-30-year-old steel jack stands with the pin which are far more positive locking than any with the ratcheting locks.
Whats more important than what jack stand is verifying the stability once the vehicle is held up by them. I would bet that any stand sold has to meet some type of standard and all will have a safety factor built in, for example 50%.
#34
While we're on the subject of jacks/jackstands/safety, I usually observe at east one fool at every DE with his car up in the air suspended by the jack alone while he blithely works on his car. In as pleasant a tone as possible, I ask him to please put at least one jackstand under there, 'cause I can't stand the sight of blood and screaming.
#35
RL Technical Advisor
Steve, did the stand itself fail as in welds opening up or legs bending, or was it the locking mechanism that failed...or maybe not latched correctly.
I can't see 1500 pound stands bending when all they have to hold up is a quarter of the weight of a 3000 pound car or 750 pounds.
#36
This is a good thread.
#37
I love this place! 35 posts on a relatively mundane, but important topic. Some really good input here for getting quality, safe jackstands. I'm looking to get rid of my ratcheting jack stands and get the flat top pinned stands from Tire Rack.
#38
I just found these at Northern tool. Nice flat tops. Not sure if they would be low enough however.
http://www.northerntool.com/shop/too...8899_200318899
#39
Hey IXLR8,
How do you afix the hockey pucks to the AL stands you found on Tirerack? Or is the weight of the car on them enough to prevent any worry of slippage?
#40
If you have standard jackstands (framerail type), I just "trim" the edges of and use these "Rennline" cups. I like that they go up into jacking point and no chance of slipping out.
#42
Esco and never look back. The car is super sturdy on them and I don't worry a bit about working on it under them.
#43
How about these rubber pads for us with existing cradle type?
http://www.harborfreight.com/2-piece...and-95952.html
or
or
#44
or
http://www.amazon.com/Prothane-19-14...MM0FBKGFQT9CE6
or
Either way, after reading threads like this, I bought a set of 4 Escos and now sleep better at night. ;-)
#45
I went JackPoint Jack Stands and never looked back. Overkill? Probably... but my life's worth at least a few hundred bucks.
http://www.jackpointjackstands.com/Home_It_Works.html
