Aluminum jack stands
Do you still have the receipt? I don't know how those can be used without damaging your car. Do a search for flat top jackstands. There are one or two options out there, none of them cheap, but worth it, I guess...
Super Moderator
Needs More Cowbell
Needs More Cowbell
If you can, return them and buy these:
http://www.acjacks.com/acjacks_004.htm
And then ask Santa Claus if you could get one of these to go with the stands:
http://www.acjacks.com/acjacks_003.htm
They're pretty much the best.
These aren't thad bad. I thought mike in canada - has a 993 targa - built a stand for these similar to the bolt through the hockey puck. Basically making a flat top out of them.
I've owned lots of these notched-post jack stands in steel, and I've never trusted the engagement. We switched to aluminum Torin jack stands and I'm very very happy with them. Around $62/pair.
![](http://www.northerntool.com/images/product/images/144441_lg.jpg)
I think the ones Eric has pictured above are the same as the Tire Rack ones I mentioned. I have never used them, but they don't look as stable as my Escos. Better than the saddle type initially pictured, though.
These are the ones I use and recommend, though they are heavy and steel:
![](https://www.pelicanparts.com/catalog/images/Tools_folder/10498.jpg)
I bought two sets of the aluminium jack stands (as well as their aluminium jack) from Tire Rack...
![](http://www.tirerack.com/images/accessories/product_images/large/trstands_l.jpg)
10.5 " to 15.5" lift range...not excessive, but adequate for my needs.
I use rubber hockey pucks between the jack stands and chassis, and jack pads when using my hydraulic jack.
No easy access to hockey pucks in Tulsa ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
However, I will try the Stanley rubber block sander holder...should work???
Thanks for the feedback. I like the flat tops & will probably order some. I may keep these for my other cars & will try the rubber block on top for the 993??? Am I crazy or just stupid? Don't want to hurt the car but can't see this being a problem?
here is the rubber block sander...i will look for play it again sports tomorrow. i need to jack my car up this week and do a few things. you guys really don't think this will work? i guess i could wait until the others are delivered but really don't want to.
