Interstate or Red Top
Is that rubber hose the vent tube in the center of the long side of the battery?
Amongst other reasons, why we use AGM batteries in military vehicles...you can't get to them when you need a hoist to remove the turret.
BTW, back to batteries...
The group 91 is the correct battery for our 993s but Porsche has replaced it with the group 48 which is 15 mm (0.6 inch) taller. Although it interferes with the plastic trim panel very slightly, its not an issue after you neatly trim off a strip...or you can just leave it as it is.
I compiled an Excel spreadsheet with group 91 and 48 batteries.
Is that rubber hose the vent tube...?IXLR8
The group 91 is the correct battery...
Thanks for the pic Rinty! So where does the other end of the vent tube go? Is there a hole that it fits into?
Where does the other end go...Zedder
I'll have another look at it tonight, but if you look at your existing battery, there should be a vent tube running from it, to the outside.
...military vehicles...you can't get to them...IXLR8
Thanks Rinty. I'll check my red car as it has an Interstate in it.
