993 Forum 1995-1998
Interstate or Red Top
Old 09-11-2010, 11:06 PM
Onami
Onami's Avatar
Default Interstate or Red Top
Battery died in the C2S...which battery would you suggest?
Old 09-11-2010, 11:10 PM
tjangi
tjangi's Avatar
Lots have been written about this... My conclusion: Interstate. Reasoning: the weight saving is not worth the hassle of battery tender, poor performance of holding charge, and risk in getting stranded.
I have an Interstate for the last 6 years and still going strong, never died during wintertime even without battery tender.
Old 09-12-2010, 12:41 AM
AOW162435
Seared
AOW162435's Avatar
Interstate.
Andreas
Old 09-12-2010, 01:40 AM
TxnBluDvl
TxnBluDvl's Avatar
I have a Optima Red Top in my M3 and a Yellow Top in my 993. I much prefer these since they remove the risk of acid vapor/overflow.
Old 09-12-2010, 11:13 AM
IXLR8
IXLR8's Avatar
Originally Posted by Zedder
Which battery would you suggest?
East Penn 648MF or if you absolutely want an AGM, East Penn 9AGM48.
Except for the case colour, the East Penn 648MF is physically 100% identical to the Porsche battery I replaced.
I prefer flooded lead acid batteries over AGM for the advantages that matter to me.
Old 09-12-2010, 11:38 AM
g_murray
g_murray's Avatar
My 6+ year old interstate died April 2009 -- changed to an Optima Red-Top. The installation was straightforward but make sure that the battery 'clamp' DOES sit on the plastic base of the battery itself. The fact that it is SEALED made, obviously, the 'vent overflow' completely redundant -- which I like. I do put a 'tender' on it (periodically) during the winter and have NOT had any problems since. The battery was approx $100, BTW.
Gerry
Old 09-12-2010, 11:53 AM
IXLR8
IXLR8's Avatar
Originally Posted by g_murray
The fact that it is SEALED...
Well AGM or GEL "Sealed Lead Acid" (SLA) batteries are not really "sealed" and have a valve in order to vent.
They vent during overcharging or any condition where internal pressure is excessive (for safety reasons).
That is the problem with "Valve Regulated Lead Acid" (VRLA) batteries which is what AGM and GEL types fall under. When they are being overcharged, and that happens without you even knowing it, they slowly lose water which cannot be replenished as in a "Flooded Lead Acid" (FLA) battery. So when do they get overcharged? In the hot deep south when your car is overcharging them or when your voltage regulator has failed.
Which is why I prefer FLA batteries.
Besides, the CCA advantage of an AGM is hardly needed the way our cars are used.
Old 09-12-2010, 12:17 PM
Rinty
Rinty's Avatar
Mark:
I got an Interstate last year, and it went in real easy. Just make sure you get the vent kit with it.
Old 09-12-2010, 12:22 PM
milrad
PS Armorer
milrad's Avatar
I put a DieHard International Group 48 in mine. No problems with installation, durability (so far) or fitting the vent hose. Plus they are easy to get at Sears and return if necessary.
Old 09-12-2010, 01:28 PM
mike cap
mike cap's Avatar
Diehard International + 1. Perfect fit !!
Old 09-12-2010, 05:46 PM
IamSMC
IamSMC's Avatar
Originally Posted by Rinty
Mark:
You have a picture of that?
Old 09-12-2010, 07:09 PM
Pete Lech
Lifetime Member
Pete Lech's Avatar
After 8 years, there was no visible corrosion on my Red Top when I replaced it. Doubt if you could say that with a standard battery.
Interesting that the cheap battery I took out of the 993 and put into the 525 (under the back seat) is still going strong, and has never had a tender on it. The 993 did and the Red Top died after 8 years.. Perhaps the BMW has a better power management system?
Old 09-12-2010, 09:27 PM
IXLR8
IXLR8's Avatar
I take it you mean corrosion at the terminals? My 11 year old OEM battery in my Honda is a standard battery and the terminals are still like day one. They were never cleaned or greased either.
Its a matter of design and quality control.
Interesting that the cheap battery I'95 took out of the 993 and put into the 525 (under the back seat) is still going strong...
Pete, don't get caught needing capacity though. Most batteries I have tested had plenty of cranking ability (they passed a load test at 1/2 the CCA) and that is all we judge a battery by if we are users.
But if your alternator or alternator belt fails, chances are you'll never make it home on battery power alone unless you are close to home. I made it home from 110 miles away because I installed a new battery. There was nothing wrong with the old one; it started the car and it even marginally passed a load test, but I noticed other signs that had me replace it.
Old 09-13-2010, 12:46 AM
Rinty
Rinty's Avatar
You have a picture...?IamSMC
A special trip out to the garage, in the rain, to take this pic for you, my friend :
I put away my tools many years ago, but installing this was an easy 10 minute job. I like the flooded lead acid batteries for applications where access is not an issue.
Old 09-13-2010, 08:37 AM
DanL993
button queen
DanL993's Avatar
That's what's great about this forum. I'm not looking for a battery right now, but this discussion is worth printing and saving.
Lotsa great advice here. Thanks guys.
Quick Reply: Interstate or Red Top
