993 Forum 1995-1998
Hole in rubber boot
Old Sep 5, 2010 | 01:54 PM
mawyatt's Avatar
mawyatt
4th Gear
Default Hole in rubber boot
Noticed I have the a hole in the rubber boot sitting on top of the fan. The hole is about 3" by 2". Seems the rubber is deteriorating and breaking apart. I need to take the car in for service soon and wanted to know if it's OK to drive until then. What is the boot's purpose?
Old Sep 5, 2010 | 02:03 PM
ilko's Avatar
ilko
Agent Orange
It supplies air to the heater fan. your problem is not uncommon - the boot becomes brittle with age and just falls apart. I would replace it before driving the car just to be on the safe side. The pieces from the boot can scatter around the cylinders underneath and they will cool less efficiently. Also the hole in the boot will let a decent amount of air escape from the fan before it reaches the cylinders. It won't be catastrophic if you drove the car, but it's a cheap ($60 I think) part and easy to replace.
Old Sep 5, 2010 | 03:00 PM
stace's Avatar
stace
It is a very common problem with these cars - age related. as to driving it? many of us have put many miles on the car before realizing the hole was there. Its a pretty easy DIY - either way a few miles won't hurt anything while you wait for the part or your shop to get to it. just my $.02!
Old Sep 5, 2010 | 03:24 PM
SC2993's Avatar
SC2993
There are (2) replacement boots for this part, the non-varioram part # starts with 964 and the varioram part # starts with 993 IIRC. Do a search on this and you will find the correct part # for your car. Very easy DIY.
Old Sep 5, 2010 | 09:12 PM
1pcarnut's Avatar
1pcarnut
When replacing the boot, check inside for little bits and pieces.
Old Sep 5, 2010 | 10:16 PM
C4SJOHN's Avatar
C4SJOHN
The varioram 993 part number is 993-106-403-00 the Porsche list price is $49.76 the price from Sunset Porsche is $30.79 plus shipping. I just replaced mine a couple of days ago. You just need a 10mm open end wrench and a rag to cover the opening from anything falling in the hole on top of the engine. Don't remover the three bolts all the way when removing the old one.....
Old Sep 5, 2010 | 10:29 PM
911C2's Avatar
911C2
Sory for the dumb question but I did a search and could not find the DIY instructions. Also looked at P-car.com and still did not find instructions.
Anyone have a link for instructions, please.
Thank you
Old Sep 5, 2010 | 10:48 PM
mongrelcat's Avatar
mongrelcat
My non-VarioRam C2 (9/94 build) takes the 993 part. There's more info and a photo of the two parts (thanks bart1) here:
https://rennlist.com/forums/993-foru...n-housing.html
Old Sep 5, 2010 | 10:55 PM
mongrelcat's Avatar
mongrelcat
Thank you
http://www.wbnoble.com/WN_articles/r...3_air_duct.htm
Old Sep 11, 2010 | 04:39 PM
911C2's Avatar
911C2
Thank you very much
Serban
