DDM Tuning HID Install DIY
#62
I finally installed these today. It was much easier than I thought (in fact, how to pull the light out puzzled me and then I realized how easy it is to slide it out). I'll test it out tonight.
Thanks for the write up.
-bg
-bg
#63
first i want to thank the OP for this thread.
another example of a world of good stuffs here.
my ride came to me with oem halo low beams (too weak)
and a pair of 55w 8k monsters in the highs.
the ballasts are 'ztw performance' (?) not slim and stuffed behind lamp assy.
i first bought 4300k silverstars for a modest upgrade
on the lows but was still not satisfied.
i then bought a pair of 35w 4300k hid on ebay (i forget the brand)
and after reading over this thread a few times i got up the gumption
to swap the silverstar halogens into the hibeams and convert my projectors
to the new 35w hids. they look and shine great and i also
lost an annoying short in the hibeam indicator.
my job was a little more complex than this thread
because of the removal of the 'old' hids from the hibeams.
but the logic and pics of the thread really helped.
however i am still experiencing one issue..
when i flash the brights i lose the pass side low beam and it doesnt come back
until i turn the light switch **** off (or to position 1) and then back on.
one note, the stupid plug behind the pass headlamp is loose because the bracket broke.
any one with ideas on this?
thanks john.
thanks john.
#64
thanks john.
#65
I just completed the DDM kit with 35w ballasts and 4500K bulbs. Just as it's been described in these forums a hundred times... 1st one went smooth in like 15min, 2nd one took 5 min and I even took a few minutes to remove the lenses and clean them inside. What a killer inexpensive mod for this car.
I also bought 5000K bulbs but I doubt I'll use them as the 4500's are as white as I want without being too blue. Anyone want em? $20 shipped (in the US 48 continental)
#67
Anybody has pictures of their kits installed? It would really help in determining with what color to go, 4500, 5K, 6K...lol I am undecisive!! Help me please!! I want a bluish kind of color but not that blue, Thanks.
#68
my thanks to all for their write ups, input, feedback, etc. based on what i've read, i'm leaning towards 35W with 4500 color, max 5000. i suspect with 5000 i'll have just a hint of blue from a distance. correction/feedback welcome.
#69
I've had 2 ballasts fail on me and I think it's due to the heat generated inside the headlamp assembly. There is no ventilation so I think the ballasts die prematurely. I swapped back to standard bulbs for the meantime but I'd really like to get the HID's back in there.
#70
I've noticed ballasts within the headlight housing also tends to create condensation on rainy days, real annoying!
Or your other option would be to mount the ballast outside, such as the trunk and have a long wire feed into the headlight. You'd have to drill a hole in the casing for sure.
#71
I've considered swiss-cheesing the removable cover but putting the ballast on the outside of it is probably best. It looks like it will still fit in the fender. I may do that... These work great when they stay working LOL. I had one go out in 2 months and I figured it was an isolated incident because the 2nd one didnt go out for another 15 months.
#72
I wonder if there would be any harm in drilling extra holes in the headlight back casing, just to give it more ventilation?
seems like porsche may have thought of those rainy days and were being proactive 'bout it. just a thought...
#73
Mine are inside the headlight housing and have been since 2011. No issues so far <knock on wood!>. It does appear that in the last few years the ballasts are a newer generation from what I bought. Maybe that's the problem?
HIDs (no matter what kit you go with) are a great addition to the 993! It's incredible how crappy the halogens really are at night.
#74
#75
i have the stock litronic on my targa and the ballasts are mounted out of the headlight assembly and within the front bonnnet - just above where the cd changer would be and one each side, of course. the carpet covers it all so it's a pretty clean and unnoticed when the front hood is opened and the carpet is in place.
Our cars being probably one of the first to run litronic technology had them setup with a ballast in trunk, igniter within the headlight housing connecting directly to the HID bulb. So if you ever want to go from OEM --> aftermarket (let's say due to not wanting to get overpriced OEM setup for basically 90's technology!), it's not possible to keep the ballast outside with no wire feeding into the bulb. Basically the main connector cannot handle the high voltage, so a wire needs to be fed directly from the ballast into the bulb.
