C4S going into shop tomorrow
Magdaddy,
I've got the Hankooks and I've been using them for commuting and AX. Decent. Softer sidewall, so more roll-over than the PS2s, so you'll need higher pressures for AX.
Unfortunately, you're in NY and I'm in CA, since I've got the matching 285/30/18 50% wear rears sitting in my garage.... Anyone want them? Originally posted on PCA for $200 for both, but I'd just like to get them out of the garage. I have pics if you'd like.
Magdaddy,
Magdaddy,
Don't give them away for christ sakes, thats mad mod money ya got there brother!
ok
new tires-Hankook Ventus V12 EVO K110's,225Fronts, 295Rears
Walrod bushing's
Wevo motor mounts
clutch slave and hose
front brake pads/sensor's, etc
rebuilt distributor(s) w/new belt
new caps/rotors-excessive wear, Joel thinks they are original
alignment/corner balance...there was waaay too much camber on every corner, and more on the right side, than left. A perfect setup for Pocono according to Joel-so much for a street "compromise" setup as I was told. Joel set it up to a Euro RS spec, of 1.2 degrees at all corners.
Car revs so fast now, he thought it had a LWF in it!
I also did a PPI-Post purchase inspection. Car got flying colors mechanically, really comforting.
Anyway, going to get it Friday. Looking forward to a fall meet up with some of you...somewhere.
Walrod bushing's
Wevo motor mounts
