Need rear seats and belts
I just purchased a 1997 cab with the rear seat delete option that came with lockable box that bolts down. I need to replace with seats and belts as I want to take kids out once in a while. I have taken the box out and don't see bolt holes for in center. I do not have seats or belts yet and would appreciate any help in finding and installation tips.
I bet if you offered to trade the RSD stuff for rear seats you'd get someone to come over and do it for you. a bunch of people are interested in the "rear seat delete". Where are you located? If you are near me and your stuff is black, I'll trade...
If your car is a US spec cab, then you will need the rear seats that come with the center column to mount the 3pt belt and back brace. ROW cabs (at least my 1994 did) had folding rear seats and only a two point belt.
An alternative is to remove the RSD and install RS carpeting and two point belts. This may not be technically legal.
My car was originally purchased in Arizona. Does anybody know if my car would need a weld on bracket for the center bracket that would not have been done from factory as it was originally a rsd? I have not taken up carpeting yet, but it doesn't feel like there is a weld on bracket.
I've got the full rear seat unit for a cab with everything you need (seats, frame, belts, bolts) - and it is in classic grey.
Most likely the bolt holes in the center "hump" are there, but just covered by carpeting. The DIY for the RSD will help you locate them - just do the reverse to install the rear seat framework.
Please contact me via PM or email to discuss.
