Any experience with lightweight batteries?
PS Armorer
I have a Shorai lithium in my Panigale 1299S. Super light weight and works great. It holds a charge much longer than even the Odysseys in some of my other bikes. Lithium requires a special charger though...and I use CTEKs on everything else FWIW.
For the Earthx, they provide a listing of suitable chargers/maintainers. I have the ETX24C and it's been great down to 40f with triple starts. To go with any other battery that doesn't use on-board cell management is ridiculous. You're risking a fire in a compartment with a tank and brake fluid.
No, no says I.
No, no says I.
Giving one of those few months update..... I can report my car has turned over each and every time in 40f or greater weather. If I'm away for over month, I'd disconnect and put on a B&D charger (type BM3B). As for terminal ends, the kit includes some extenders (for our larger clamp style) to mount away from the battery due to its own terminal design. Regarding mounting type and where, I just used the existing partition with some flat 1/2" metal band (the stock you find at True Value with the holes present) that sandwiches the battery to then be bolted down where the old one used to rest.
If you need more info, feel free to pm.
Michael
Michael
I just wanted to update this thread. My EarthX is still going strong after many, many turnovers. If you’re thinking about a lightweight battery, do it right and get some onboard battery management built in.
I’d like to preface my “40 degree starts and higher” in my previous posts. I live in NorCal and that’s as cold as it gets. If I did live somewhere colder, simply turning on the cabin fan for a few minutes would cause that battery to heat up and give you a nice start.
How about Your waist? Lots of 993 owners could lose the weight of a standard battery without too much pain!
Edit: Just noticed that this solution was already mentioned above!
https://shop.antigravitybatteries.co...omotive/rs-30/
just saw saw this one pop up in an add. Anyone try it yet? Could be great or could just be marketing.
Steven
All good except it tripped the low voltage switch at the drag strip. Reset after about 10 minutes and started like it had full power. (so kind of seems like it too easily trips the low voltage cutoff switch)
Can sit for about a month with no charger and still start.
Zeichen 282 (10-31-2019)
Premium Sponsor
HI all,
Scott from Antigravity Batteries here.... if you guys are interested in Lithium Batteries I'm glad to answer any questions in full detail. All we do is Lithium Battery products. from Starter Batteries used in World Class Racing to the Daily Drivers.... which means all Motorsports and Powersports and beyond. We also were the first company to introduce the mini Jump Starters back in 2013 and have sold just under a million MICRO-STARTs since that time. So we know lithium batteries inside and out.
As I said I will be glad to answer any questions, but I can also point you to a recent thread we have had going for the last 2-3 months discussing every aspect of Lithium Batteries.... It was on the GT3 Forum area and it pertains to all cars using Lithium. You can read it here.... https://rennlist.com/forums/991-gt3-...for-2-gt3.html it gets very indepth at times also. So if you read it you will be very well versed on Lithium Batteries.
To give you some basics on lithium batteries.... most of the batteries that people had mentioned above are lithium batteries with an application oriented more towards Powersports and Motorcycles, though they are using them in their cars.... and that can absolutely work fine but does require a little more monitoring because these smaller models have a lower Amp Hour than a dedicated Auto Battery. So a smaller lithium battery, especially in more modern cars can overdischarge quickly due to the extra electronics and computer systems on board in a modern car. So be watch full of that. We have tons of people using the Smaller Batteries in daily drivers... but it isn't the best application unless you are willing to monitor the battery a little more. But for Track and Racing they are a massive weight saving product at a fraction of the cost of other weight saving products. For example 15,000 to lose a few pounds with Carbon Fiber or Titanium... a few hundred dollars to lose 40 lbs with battery change in 10 minutes....
Anyway I wanted to show you an Automotive version of our Lithium Batteries called the RS – 30 that was released earlier in the year. I put a video below so you can check it out and learn what it does. What differentiates our Antigravity Battery products from other brands is that we offer a specifically automotive battery but additionally it has protections built in that many other battery makers do not offer and these protections will NOT allow you to accidentally over discharge and damage the battery or overcharge and damage the battery. At this point in time they are the most technologically advanced batteries you can buy for Starter Battery applications. Additionally our line of RE-START batteries has a reserve capacity so that in case you left your lights on or did something to accidentally discharge the battery, the battery will actually monitor its voltage and put itself to sleep before it is fully over discharged and leave you enough reserve capacity to start your vehicle and drive away again. You would just press the "restart" button located on the battery and start your car again without having to put it on a charger, or jump start it, or get assistance. Its very cool.
So if any of you have any question feel free to ask. I will speak in facts only and of course though we sell lithium batteries I will not over-hype or lie about our products or try to bash competitors. . For those wanting the benefits of Lithium such as lightweight, more power, and something cool like the RE-START feature then the benefit of lithium are great... but if you don't need ultra lightweight, or drive your car in close to freezing temperatures often, then lithium may not be the best option. But I can give you the actual facts and educat you about them so you will be able to make an informed choice.
Odyssey ER 40 caught my eye, specially 27 LBS weight. What do You think about these reduced weight batteries. Beside swapping heavy electric seats to raacing seats, this should be second considerable weight-gaining point?
http://www.odysseybatteries.com/battery/er40.htm
Sunroof delete and rear wiper delete after that...
Premium Sponsor
I have the RS pulley and run with a Voltphreaks battery. Absolutely no issues staying charged, and dropped 40 lbs. of dead weight. I don't even use a trickle charger anymore - I just turn the battery off. Look for the on/off feature in whatever lithium battery you buy.
