I might be barking at the moon!
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
I need a tire for the BMW because I have an alignment problem.
I have this feeling that finding a Goodyear Eagle F1 GS-D3 in 235/45-17 might be looking for a needle in a haystack. I don't think it is a common 993 size. Isn't 225 the better size on the 17s?
Anyhow, thought I would throw it out there as the other 3 are still good and have 10k or so left on them. At the rate I drive the BMW, it might take 2 years to rack up that mileage.
Cheers!
Cheers!
Thanks...it's a crap shoot. I am calling but thought I would spread the net a little wider!
Cheers!
Cheers!
try craigslist ,
The trick is to type "craigslist" into google then hit return, First result will give you a field to enter your search for ALL craigslists sites, not just you local one. Good luck with the needle
Thanks for the Craigslist global search! I was looking local but not finding anything.
I did get an offer from a guy in Albany NY for two almost new ones. Just need one used one till I go all new on the car.
Cheers!
Cheers!
