Rennline RS heater bypass install
Contact the guys at Rennline. I am sure they will help you sort it out. Good guys who stand behind their products.
I bought a CF piece from Fabspeed. Had same problem. After I complained, they tried to install one themselves and found it wouldn't work. They gave me a full refund. (Thanks Alex!) Said they were designing an extra piece to make fitment work. Don't know what the status of that is. I ordered an OEM piece from FD and had a hell of a time installing it too. But, after several hours of cussing and sweating, it finally went in. Secret is to fit it into shroud first - counterintuitive. You must have the 964 shroud - which is what came on '95 993s. Not sure when they switched to 993 shroud. CF may look cooler, but the OEM plastic works!
![Thumbs up](https://rennlist.com/forums/images/icons/icon14.gif)
My original post was a half part venting frustration, but more importantly a head's up to save folks the same aggravation. You rightfully point out I owe Rennline the chance to make things right - heck, I am willing to drive over to their shop sometime and they can test fit themselves.
I am a little busy with work at the moment, so I am going to close this thread until I have time to follow up properly with Rennline.
I will report back asap.
Best,
Matt
